anticipating with enthusiasm the launch of the P18
Fair enough, direct injection is new (and a long time coming!)720 and 750 both have twin scroll turbos, btw.
I'm guessing that's one of the reasons for a new engine design. I'm interested to see how the throttle response will be on it without a hybrid boost. I drove a Supra a few days ago, and it made my engine feel super laggy.Fair enough, direct injection is new (and a long time coming!)
I agree with this. It's definitely better than the renders, but the design certainly doesn't "wow" me like the P1 did. It doesn't look bad, even good, but not great.Not really moved by the design but the specs and engineering in this is insane. Bravo McLaren
Yeah I saw that, maybe he will review it in a year or two.
He actually gave some commentary on its looks etc. Other videos, so far, have just regurgitated the McLaren marketing talking points.Yeah I saw that, maybe he will review it in a year or two.
Noticed right away that massive rear subframe. Really surprising.I snapped some frames from Mclaren's video, that are showcasing some additional details that they don't show in photos.
The front subframe with the inboard suspension, heave damper and 3D printed control arms and uprights:
The rear subframe with the z-bar and active drop-links:
The suspension is actually quite interesting. If I am seeing it right, Mclaren have - as with the Artura - abandoned the crosslinked damper system, or at least in the form they've used previously. Instead we get a conventional (?) anti-roll bar in the back and a heave damper in the front (which, I assume, doubles as an anti-roll bar, since I don't see any other way to control roll from this picture, unless some components are missing). In the back, the selective control is now accomplished by the active drop-links attached to the z-bar. This is actually quite novel and something that I haven't seen before, as the way it is installed it would actually function as a "pro-roll" bar, rather than anti. Which doesn't really make sense. So maybe the way they interlink the dampers now is not by connecting the main dampers, but by connecting the heave damper up front and the drop links in the back. Or maybe it's something completely different, hard to tell without more information.
What's a bit disappointing to see is that Mclaren are still using a big and bulky alu rear subframe like this. In the hypercar sphere, you would expect either a CF subframe, a semi-stressed engine, or both. Alu front subframe too. In that sense, the Mclaren F1, is still more advanced even 30 years later.
On the positive side, the W1 keeps both hydraulic steering and hydraulic braking, while almost everyone else has moved on to electric/electronic. They are also keeping with the idea of a limited slip diff and abandoning the open diff with active rear braking, same as on the Artura, which is probably what they'll be doing with other models going forward.
What's the difference between a z bar and a conventional anti roll bar linking the control arms?I snapped some frames from Mclaren's video, that are showcasing some additional details that they don't show in photos.
Not sure, but these look like they could be accumulators-what do you think?I snapped some frames from Mclaren's video, that are showcasing some additional details that they don't show in photos.
Something doesn't seem right here, that they would be putting ALL of the suspension support load via that spindly little uplink rod... I just can't make out where else the "coilovers/springs" would be "acting" upon the control arm(s) in order to take the load...I snapped some frames from Mclaren's video, that are showcasing some additional details that they don't show in photos.
Well, for it to function as an anti-roll bar, you want the wheels moving in the same direction with respect to the road. So if one wheel goes up, you want to force the other wheel to go up as well. That way they stay level and the car stays level. That's what the anti-roll bar, which is usually U-shaped, accomplishes. But if you look at the Z-shaped bar they've put on this car, it forces the wheels to go in the opposite direction instead.What's the difference between a z bar and a conventional anti roll bar linking the control arms?
Yeah, but that's just accumulators for the normal dampers, since the dampers need to be short. That's just a packaging thing.Not sure, but these look like they could be accumulators-what do you think?
You mean the front push rods are too thin? I mean, I assume they calculated that. With the right geometry where they are never subjected to bending/buckling forces it should be fine even with that cross section.Something doesn't seem right here, that they would be putting ALL of the suspension support load via that spindly little uplink rod... I just can't make out where else the "coilovers/springs" would be "acting" upon the control arm(s) in order to take the load...![]()
Is that rear wing street legal???![]()
(McLaren Active Long Tail rear wing)
I can't wait for McLaren to go around the world and break records at every track.Just found this little tidbit and not really sure of its reality but pretty cool either way....
1.5M views · 32K reactions | McLaren W1's retractable wing is 🔥 #McLaren #McLarenW1 #Hypercar #CarFeatures #Spoiler | Top Gear
McLaren W1's retractable wing is 🔥 #McLaren #McLarenW1 #Hypercar #CarFeatures #Spoiler.www.facebook.com
EDIT: Just stumbled upon this too:
Exclusive: "12 Jaw-Dropping Secrets About the New McLaren W1 Hypercar That Will Leave You Speechless!" - The World
The W1 is McLaren’s fastest and most powerful road car to date, showcasing innovative features like 3D-printed suspension and a shape-shifting body, which adds depth beyond its remarkable performance. McLaren reserves its prestigious ‘1’ badge [...]lifestyleroom.net
Very color dependent. There will be some very cool specs…Some colors compliment the car quite well and others don’t…This car looks awesome. You guys are crazy
