21 - 40 of 50 Posts
Discussion starter · #21 ·
Just used it on my Artura and it is awesome. Connection was solid. Wirelessly connected to the ottocast no issues. I have been using it with Android auto so far so good.
First issue I have is that I can activate voice assistant, but then it doesn't do anything. Second, how do I switch between android auto and then back to ottobox android?
Exit on AA as you would normally do.
Discussion starter · #22 ·
Few quirks discovered in the last few days, if you keep the unit connected (as I do) whenever your Artura infotainment system goes into sleep the ACP "menu button" might become unresponsive. Either you wait it out till the next start or reboot the infotainment system by holding the home button for 10 seconds.
Also the on the couple version of the Artura, since it's a complete carbon fiber tub, the GPS signal is really poor if you keep the unit in the armrest to the point of never locking in satellites. I found out that if you leave the unit in the cup holder which by the way is a perfect fit it'll lock in satellites eventually.
Can also confirm ApplePie Ultra works, and works extremely well. Same idea as the Ottocast. Runs a newer version of Android, but doesn't have Otto's better interface if you want to use it standalone. But it picks up and pairs my Android or my wife's iPhone within seconds of the car booting up. Usually before we even pull out of the garage.
Ottocast does take me about 30sec-1 min to fully startup and get to android auto. How fast does ApplePie Ultra get to Android auto?
Just recorded it (but I can't post links yet). About 10-15 seconds, and that was mostly my phone starting up Android Auto itself. It's just as fast as native wireless AA in my Taycan and EQS.
but the thing is i did bring this up to service.. they plugged in and the apple car play worked so they were like its of no issue !
I just bought the Ottocast for the Subaru. I can connect to the car on the phone with a wire, but it took three different cables before it worked. The Ottocast connected perfectly first time, but I can't get the phone to connect to it wirelessly, it knows it's there because there's a message about Android Auto trying to connect but it never establishes a connection. The phone is still on Android 12, which I suspect is the issue, I'll be updating it in a few weeks probably to 14.
Discussion starter · #33 ·
Best work around is delete the phone BT pairing from the car infotainment and phone also. Then fire up the Ottocast (or whatever the vendor is) Then under Ottocast there is an app called "Multiplay" then on your phone you should see an "AA" or "ACP" request just accept as you would normally do, and then it'll work.
The main problem is when you connect BT to your car's infotainment, and the Ottocast, and the Multiplay and some others, it create confusion on the smart phone ends and just from one connection to the next.
i'm running ios 18.3 and it didnt work .. the device do connect and shows apple car play but neither blue tooth or carplay display
I tried that! The process is very confusing at first, but when connected to Ottocast, the phone shows up on the home screen in the corner, but Android Auto still won't connect, so the Ottocast has no Internet connection.
Discussion starter · #38 ·
Update on the flat cable, it doesn't work, it feeds power but data is no passing through. So it's a fail.
On a side note I have installed Highway Radar and connected my R8 to my Ottocast over BT and now I have a connected Radar detector showing up on my Artura's infotainment, pretty slick!
Also R/Tach works, not as good though R/Tach App
Ok, I tried it again after opening the Multicast app, then pairing, and it worked! Android Auto connected and the map went live. Thanks for the help!
21 - 40 of 50 Posts
