So did a compression test on my 12c now, 45k kilometers on clock.
reason: blowing blue smoke at startup and idle front left bank and constant left bank cylinder misfires.
Results:
Cylinder 1 - 85 psi
2- 82.5
3 - 85
4 - 67.5
5 - 90
6 - 90
7 - 82.5
8 - 80
So whilst i wasnt sure if my smoke was from bad rings, valve, gasket, cracked head, piston, pcv or turbo, the results show that the left bank (cylinders 5-8) are all actually quite good, so out comes to the turbo tomorrow because everything pointing in that direction for now.
BUT: See how low down Cylinder 4 is. Injected some oil in there and re-ran test, no change. So rings / piston fine. So more than likely an exhaust valve going bad. That being assumed as some people say results must be within 10% variation. Others say 25%. but maybe the whole engine is bad cause others say results should never be below 100psi.
SO who knows, but at least i am of the opinion my engine isnt going to blow up anytime soon from the crank and its only a turbo seal repair, which in all honesty is actually so much cheaper and easier than a head / block repair.
Just thought i would share.
Results:
Cylinder 1 - 85 psi
2- 82.5
3 - 85
4 - 67.5
5 - 90
6 - 90
7 - 82.5
8 - 80
