1 - 3 of 3 Posts
If anybody is still interested in the problem with the windshield wiper motor going bad. It was a relatively easy and quick fix.
- wiper motor was not working anymore
- message in the display to go to the workshop
- Just got the motor out (that was the tricky part). I could give details, if someone needs them. Just pm me.
- unscrewed the bolts on the Motor. Pulled the cover.
- I saw that one of the three contacts got stuck.
- bent the contact housing a little bit with a screwdriver, so that everything moved freely again. Cleaned everything with compressed air
- the contact and motor was working fine again. ??
Compared to the McLaren Workshop, it took me half a day and not 3-4 weeks. Was definitely worth the try.
Greetings
  • wiper motor was not working anymore
  • message in the display to go to the workshop
  • Just got the motor out (that was the tricky part). I could give details, if someone needs them. Just pm me.
  • unscrewed the bolts on the Motor. Pulled the cover.
  • I saw that one of the three contacts got stuck.
  • bent the contact housing a little bit with a screwdriver, so that everything moved freely again. Cleaned everything with compressed air
  • the contact and motor was working fine again. ??
Greetings
`Could you PM the steps you took to remove the wiper motor ?
1 - 3 of 3 Posts
