...and why I left the GT2 for the 12C.
I have owned a 997 GT2 for several years now - purchased used with <200 miles on the odometer. Over 3 years of ownership, my experience has been sublime - a very fast daily driver with excellent driver feedback, phenomenal road feel, incredible reliability, with behavior that is worthy of both the track and routine use. With the exception of the plugs and coil packs, the car was easily serviceable, and relatively inexpensive. The best of all worlds - fast, friendly, well behaved, scalpel like reflexes, and reliable.
As time has passed, circumstances in my life has left me looking for an alternative to the GT2. Although I hadn't considered a British sports car before, the heritage of McLaren, their dedication to motor sports, their pedigree, and their release of an mid engined sports car that is in the price market of the GT2 made it an appealing choice. After much deliberating, I have sold my GT2 and purchased a MP4-12C.
After a long weekend behind the wheel through the open roads of Wisconsin, I have found McLaren's offering to be a worthy alternative to the GT2. In fact, there are many things I find about the 12C that I believe Porsche can learn from.
With the imminent release of the 991 GT3 to the public hands, I hope Porsche hits the R&D department hard to incorporate the technology available in competing sports cars into the 991 GT2.
This is not a debate on double clutch transmissions versus manual transmissions. But I have no doubt that the pricing schedule for the 991 Turbo S will put the 991 GT2 in the same market as the 12C. Here are a few thoughts.
1. Weight
993 GT2 2,855 lbs.
996 GT2 3,153 lbs.
997 GT2 3,170 lbs.
With the availability of carbon fiber and other light weight technologies, Porsche needs to refocus their efforts in reducing the weight of their vehicles. We all know the performance benefits of a lighter vehicle. And while the 991 GT3 incorporates newer technologies to improve handling and power, it will be the heaviest GT3 ever produced. Hopefully, this will not be the case with the GT2.
McLaren incorporates a carbon fiber tub, and makes every attempt to shave weight. Working with Carbo Tech in Austria and Toray in Japan, McLaren is able to produce a complete single-piece carbon-fiber "MonoCell" for the 12C in just four hours. In the previous F1's chassis, the labor required 3000 hours and 100 people. In the MB SLR, it still required 400 hours to produce six carbon-fiber pieces that were then mated together to form the tub.
To bring the cost down and increase the speed of production, the MonoCell uses a new Resin Transfer Molding (RTM) automated process. Sheets of dry carbon-fiber cloth are cut into shape and laid out in a 35-ton, 7-piece steel mold that closes and is infused with resin. The carbon-fiber tub is subjected to 218 psi of pressure at 167 degrees Fahrenheit. After curing two more hours at about 260 degrees F, the tub is then released.
The unmachined MonoCell is already within 1 mm of design specifications. Improve tolerances to F1 like specs, the tub is sent to a computer-controlled milling machine for finishing touches. Because the RTM process can accommodate complex designs, the single-piece hollow tub incorporating different shapes and attachment points is possible - it is the same tub found in every version of the 12C, form those designed for motorsports, to the ones making it to the end consumer. McLaren reports that a single MonoCell tub weighs 165 lb. It is some 25 percent lighter and stiffer than a comparable aluminum chassis.
Other weight saving measures include a lighter wiring loom with a hexagonal cross-section is employed, shaving another 8 lb. And for the car's Airbrake, a flap that rises to help slow the car down above 59 mph, engineers determined a smaller motor could be used for deployment by using aerodynamic forces to assist in its elevation, maximizing braking assistance. Overall, the McLaren MP4-12C's dry weight tips the scale at 2945 lb.
2. Exhaust
Watch the first 10 seconds of this video:
McLaren MP4-12C vs. Ferrari 458 Italia vs. Noble M600 vs. Porsche 911 Turbo S- EVO Magazine - YouTube
We all know that the aftermarket exhausts on the can improve the enjoyment and visceral appeal of driving a sports car. Can Porsche please spend more R&D time improving the exhaust tone of their forced induction cars?
The MP4-12C produces an impressive sound. Unlike Lamborghini's, Ferrari's or the LFA's bark, the 12C produces a satisfying high reving scream with satisfying burbles as the RPMs fall, and a hint of turbo whispering in the background. During WOT, the exhaust produces a grunt that climbs to a scream over 8K RPM.
3. Driver oriented environment.
This:
or this:
Why do PDKs still have a center shifter?
4. The balance between performance and daily use.
With regards to performance, as has been reported elsewhere, the 12C is very very quick. From a standing start, with no technological gizmos, the acceleration feels similar to a naturally aspirated car until the engine reaches boost threshold, after which, the car moves to the next zip code. The turbos respond quickly, and like most forced induction vehicles, requires about 2500-3000 RPM to be in the threshold zone.
The acceleration is nothing less than violent and unrelenting. With the double clutch SSG, there is no perceivable lag as you move from gear to gear in motion. The brake pedal feel is very stiff, but the modulation is excellent. Carbon ceramics are optional, but the steel rotors (like the Porsche) are very very good and are significantly cheaper to replace.
The dual-clutch transmission is excellent. Shifts are lightning fast especially with pre-cog, and the paddles provide a satisfying pull and click as you load the next gear. The paddles are mounted on the wheel itself, which allows the driver to maintain hand position as the wheel turns around. The steering wheel is circular, but not a round tube - it is elliptical providing the driver a sensation of grip and confidence with perfectly positioned paddles.
The most impressive feature I have found is the hydraulic suspension. I have never been in a car as comfortable and as compliant to Wisconsin roads as the 12C. And I have never experienced a true transformation into a track scalpel until this weekend. When the handling knob is turned to track, I experienced a complete transformation - as if the spring rates have changed on the vehicle. No other vehicle has come even remotely close to the flexibility of the 12C.
When I dial the handling to "Normal" the ride quality is as compliant as a Honda Accord. No bone crushing, back breaking jarring like a GT-R. In fact, I believe there was an accelerometer test showing the forces recorded in the cabin were as compliant as a Rolls Royce. This is a car that you can truly drive every day without visiting a chiropractor.
1. Weight
993 GT2 2,855 lbs.
996 GT2 3,153 lbs.
997 GT2 3,170 lbs.
2. Exhaust
This:
or this:
