1 - 16 of 16 Posts
After my car is warmed up, if I shut it off and restart again (eg. getting gas), the crank would be extremely weak. Sometimes, the crank is so weak that the car wouldn't even start. It would start on the second attempt though.
Has anybody else experienced this on their cars? :confused:
Yep Michael,its always been like that,but it usually fires up.Only happened to me a couple of times were I had to re-start the car.Seems to be one of its foibles !!
Mine's done it once - on a restart immediately after shutdown.
mine had the low oil light come on with an alarm going off in the dash.
There is an oil pressure switch retrofit kit for that. A known "issue", but electrical only, not a real oil pressure concern. Nonetheless, get it checked because should it be a real problem, a bad result. Remember to check your oil level while waiting for your dealer to respond.
Thanks I took mine in for the oil switch, new Nav unit and iris update
1 - 16 of 16 Posts
