water dropping
4.8K views 10 replies 6 participants last post by  Mohamad Sabehtaayon
#1 ·
today during a pure mclaren ride, after we parked for a while, i found water under the motor ?, so i left the ride and added water while engine running, no error message, no overheating!
my vin number 840 2012 12c
you think is a major problem?
18000 km and still under extended warranty
#4 ·
Does it have any colour? If not, it's almost certainly nothing to worry about.
Don't open the coolant system with a hot / running engine - it is a pressurised system. You should also use the correct coolant, not water, and certainly not tap water (if that's what you used). A small amount shouldn't hurt though.
#9 ·
It's doubtful there is any damage however depending on the head design low coolant can cause localized hotspots that might not get picked up by the coolant temp sensor. Had a car where this occurred, the head shifted slightly and tore viton (sealant layer) off a MLS headgasket. In this case 2 liters seems like a relatively low amount of coolant to be missing, about 10% so it's probably fine.
