http://www.worldcarfans.com/113052958191/watch-the-mclaren-12c-spider-hit-346-kmh-video
If this is real car is near top speed of P1
If you look a dyno charts for the MP4, it's clear they're understating torque. McLaren claims 443lbft at the crank but they put out 415-420 lbft at the wheels (which would equate to about 475-485 at the crank), and that was before the software upgrade.Wow! Looks like McLaren are doing the Porsche thing were they are conservative with their 'official' numbers.
Bodes well for the P1!
Don't trust those Europeans,whats wrong with feet and inchesBlimey, that's 214 MPH in old money.....
Maybe the speedo was calibrated by Meridian and starts at 62Might have been a "press car" ?
No, no, McLaren would never do that![]()
Ok, it's 1,129,920 feet per hour. My calculator won't stretch to inches. It's a lot!Don't trust those Europeans,whats wrong with feet and inches![]()
I don't own a 12c, but the traction control light seems to be blinking. I thought it had to be turned off before it can go on the dyno? also Im pretty sure thats wind buffeting noise in the back ground, also Its quite common to launch from second gear...PHONY
count the shifts the McLaren hits its top speed in 6 gear top speed in 7 gear is 186
You might be able to do that on a Dyno no wind to push through and you can hear the Dyno wheels rolling to a stop in the video.
I think you are mistaken. There are five shiftsPHONY
Your correct I counted the shifts wrong, but I still think it is phony. McLaren states top speed 205 in 6th gear and 186 in 7th I just don't see how it is possible.I think you are mistaken. There are five shifts
71 kph - 1st to 2nd
110 kph - 2nd to 3rd
158 kph - 3rd to 4th
208 kph - 4th to 5th
270 kph - 5th to 6th
I'm not sure there is a static dyno in the world that could handle continuous running at such high speeds. The shift into 6th occurs at 1m05s in the video. The run to 356 kph takes us to 1m55s and the car doesn't really begin to slow down until 2m05s. I'm not even sure the car would survive a minute-long top speed run without the amount of airflow into the radiators that would be generated by those speeds. You certainly aren't going to be able to mimic that much pressure with portable fans.
Ready to be corrected if I am wrong, but we're talking about Sport Auto here and they have a pretty impeccable reputation for going above and beyond with their testing to get it right.
The caption on the video also says the speed was nearly matched with a GPS recorder at 343 kph so not much speedo error in play here.
The thing about speedo error is correct I just tested mine against the Vbox GPS at 50 it was 1 MPH high at 100 it was 2 MPH high seems pretty close. My Murcie is high by 8.5%I think you are mistaken. There are five shifts
71 kph - 1st to 2nd
The traction control light was flashing because he used launch control, you can also see the RPM held at just above 3000 then it jumps up the car hooks and it drops back a bit that is how launch control works . Everything looks correct in the video, but it is hard to believe Mclaren is of by 10 MPHI don't own a 12c, but the traction control light seems to be blinking. I thought it had to be turned off before it can go on the dyno? also Im pretty sure thats wind buffeting noise in the back ground, also Its quite common to launch from second gear...
Ah! So you remember the mighty Subaru Impreza 22B.^ I don't think that McLaren is "wrong", I think they are just being humble/conservative with their published numbers. Like how every turbo Japanese performance car in the 90's made 276 horsepower![]()
