1 - 5 of 5 Posts
This item is used for less than 1,000 miles and in excellent condition. It is a simple plug and play solution for extra performance out of your MP4-12C. It is the only way to add a performance tune without leaving any trace or voiding/affecting your warranty/Extended Warranty. Works with all years McLaren MP4-12C, spider and coupe.
Three selectable power levels. # 2 worked perfect for me but its your choice and depending on other mods you may have/use.
Includes a jumper plug were you can bypass the system with one simple connection making it 100% stock without full removal.
Comes with everything pictured and will include the manual/installation instructions as well.
Currently listed on ebay with paypal payment. EBAY LINK https://www.ebay.com/itm/174106599120?ul_noapp=true
Yes especially in level 2 or 3. So here is how it worked for me...
Level1= I couldn’t really feel any power increase but what I noticed was the lack of any lag when pressing the throttle. Furthermore I noticed great acceleration on the highway without the need to downshift. Basically made the car ready to run rather than feeling bogged down like stock is.
Level2= This was my fav deff felt the power, higher mph and the hp/torque just covered the same ground much faster and wanted to go even faster to red line.
Level3= So much more torque difference that it would trigger the traction control sometimes. Even more mph then level 2 like if I got so far in my testing run I had to slowdown because I ran out of room. When I used level three I would also use a can of boostane in the gas just to be safe and almost always used it in track mode to avoid traction control killing performance.
1 - 5 of 5 Posts
