Only Gunfick Der Russetor has the answer...The corsa will run hotter... Not sure about pressure, but that will be some of what those settings are about
From what I have read ( would be glad to be corrected) nitrogen is better because it hold less moisture and is better for corrosion of the alloys,i thought it was because it was more stable for temp and pressures,but apparently that makes little differenceHas anyone filled their tires using nitrogen?? If so have you noticed any difference? Cheers.....
So andy have you had yours done, yea or nayFrom what I have read ( would be glad to be corrected) nitrogen is better because it hold less moisture and is better for corrosion of the alloys,i thought it was because it was more stable for temp and pressures,but apparently that makes little difference
Of course Gunfick der russetor will know the answer,but i don't think he inhabits this site too often!!
