1 - 20 of 20 Posts
Travelling to work last week... at the traffic lights I hit Neutral to prevent the "creep". At the second set of lights after neutral when I engaged 1st - the car flashed this message.
Upon driving off I realised I lost 2nd gear. The car went from 1st to 3rd skipping 2nd. I was driving in auto. I took it to the dear who was stumped, MTC was stumped and have decided to swap out my transmission. To my surprise, the dealer had spare a transmissions in stock. A 3 day job.
Any one had this same problem before?
There has been a small number reported........mostly after reporting leaks , from memory.
Had the same thing lung a couple of years ago. Never did know what the problem was.... Second box was faultless...
That's one advantage of a Mclaren tboigh. The dealers have to have every part in stock so there shouldn't be undue delay in getting you back on the road.
Yup! I was very impressed when the chief mechanic called and said that they will replace the box which they had in stock. :eek:
Really? I imagine they keep a bunch of smaller stuff in stock, but I'm very surprised and impressed if they keep something as major as a gearbox on hand.
That is dedication to your customers. A spares shop in every dealer to get you back on the road.
Quite impressed that there was a spare gearbox around in the Singapore dealership it has to be said.. but I suspect I might test just what kind of range of spares the dealers are obliged to keep at hand.. Would be very surprised if I ended up not needing anything to be ordered from the factory....
Discussion Starter · #11 ·
Normally with other marques you have to wait a few weeks for a part to be freighted in. Having a spare transmission box (and I saw it today... it is a big sucker)in stock is something special.
Two thumbs up!
curious as to what the cost of the transmission is if it wasn't under warranty...
You guys are funny. I would be more disappointed about the Gearbox being replaced then celebrating that McLaren provides such excellent customer service.
BTW - My service advisor said that basically IF you are going to have Tranny issues(Gearbox not sex change:D) then it is going to happen in the first 1-2K miles. Otherwise you should be good to go for a long time. IIRC Porsche says that their PDK will easily last 100K miles.
Ritesh,i was told be the head of development at the MTC,that he would expect the engine and gearbox to last 200k miles as an average,id be happy at 150k ;)
2015 650s
Hi guys
I had exactly the same issue... after driving 10miles , the transmission skipped second gear taking off from the stoplight and went from first to third in auto mode.
I parked on the side ; turned off the car and back on ; everything was normal for the next 20 miles even with rough driving auto and manual...
Weird ... only 11000 miles on it.
2015 650s
What is the warranty on those trannies? My car is 2015, bought it used last year and didn’t get the extended warranty ... shouldn’t the drive train (engine and transmission) still be covered?
Sponsor
Your warranty is probably gone. I have a remanufactured transmission available. Let me know.
X
1 - 20 of 20 Posts
