Hi all,
Here is my experience and most recent episode with the MP4:
I did a small acceleration and suddenly clutch over temp symbol appeared for the first time followed by a transmission fault error. I took it home (have a 4 post ) and checked the fluid levels first for the clutch. It was missing a large amount and inspected the transmission fluid and it was completely full with about 6 quarts over the fill hole (no exaggeration). Indeed, the clutch fluid is in the tranny! :/ How is the clutch fluid getting into trans?
After the error message and before knowing the issue on the way home gear engagement was difficult and gears would slip to neutral and only engage from 2nd to 4th. I think the tranny is toast. Has anyone ever opened up the cover to verify this type of issue? Is it worth opening up the trans to a particular section of the trans where this spillover can occur such as loose bolts separating sections?
Btw, the above happened after twice servicing both the trans and clutch (including new filters).
