So this suggests that it's not the tire, in and of itself. Therefore, it's some interaction of these tires and your particular wheels and tpms sensor. Can confirm by borrowing another 765LT (yeah I know, not practical at all) and trying your wheel/tire/tpms combo on the other 765 vehicle. The OEM wheels you borrowed, are they the same model wheel ? Theorize maybe the sensor isnt sitting in the precise location because of the thickness added by paint or powercoat. Lastly, can consider a new set of OEM wheels in gloss black, if you love these tires...I know, it all sounds fucked, I'm sorry.He then put my R888R on the other OEM set. It worked.
I'm going to repeat this one last time. It's the wrong TPMS sensors being ordered or an idiot tech that doesn't know how to do his job, or both. It's logical deduction, those are the only possiblities left. I'm leaning towards an idiot tech because only an idiot would suggest the paint on your wheels had anything to do with it. Not even slightly logical.
Is it confirmed your wheels and tpms work with any other tire out there apart from the 888? I know you mentioned "they" put back on the trofeo and it worked in your first post, but have you personally confirmed this?
Wow, what an ordeal. I feel for you. At this point, with all the info you have given, it sounds like it's the R888R that you have. Maybe a batch that was out of the norm or different in some way to the R888R's that have worked for other 765LT. I guess you can compare the tire sizes/specs you are using to those who have used them successfully on their 765's. I'm totally guessing, but I'm theorizing with you that somehow it's the metal belts / beads in this specific set of yours that are somehow interfering more with TPMS sensors. And yeah, if you could find and hook up with another 765 that has a working set, then you could experiment with them by swapping out wheels/tires etc... If not, consider another set of R888R's (either same or different sizing) or just abandon ship? Good luck man.I misspoke.....we then put the R888R on OEM wheels and it did NOT work on my car. Sorry. Only other thing to try is to put my OEM wheels/R888R on another 765. The other set of OEM wheels were the diamond cut ones.....but it can't be the wheels as my R888R on his OEM wheel didn't work.
Peter
This is getting a bit ridiculous. Much as I'm curious as to why this isn't working, it's time to say that it should not be your problem. TPMS must be able to work with non-OEM tyres, or there is a, warrantied, issue with the car's design or manufacture. This should firmly be for McLaren to diagnose and fix, at their expense. With that said, I'd also ask Toyo if they have had reports of TPMS not working with recent R888R tyres.I misspoke.....we then put the R888R on OEM wheels and it did NOT work on my car. Sorry. Only other thing to try is to put my OEM wheels/R888R on another 765. The other set of OEM wheels were the diamond cut ones.....but it can't be the wheels as my R888R on his OEM wheel didn't work.
Peter
One complication is that this is a digital system. It could be that the signal is of very low quality (e.g. bad ground, TPMS receiver, interference, etc) when it works, so minute differences are enough to stop it.
Good luck,
Roger
Should NOT be an issue... I've run (previously) R888 on rears and OEM on fronts with no issue and R888R on all 4 wheels with no issue... more likely a gremlin in the techo !They are inferring that the R888R's have more steel in the belts than the OEM Trofeo R's and that's what causing interference resulting in TPMS not reading. Also, I have several friends running R888R's in back and OEM Trofeo R in front with no issue. I asked the dealer if the front or rear was giving the error code and they told me rear.....(shaking my head).
Peter
This is interesting. The push is clearly towards making it more difficult to run anything other than the OE tyres.I'll try an hypothesis here, but I might be talking nonsense.
Coming from an Artura presentation, the techs guys make clear that it's not possible to fit anything else than the specified Pirelli on that car. The sensors are specific to those tires and the car won't let you do a launch control if they are too cold or outside the recommended psi, etc.. By the same relation Sensors to car's computer, the different driving modes will be available or not.
Did you get a software update on your car? Did McLaren plan to push that software across the whole line of cars?
That doesn't sound like a good move for owners, as tyre performance moves on, and some will want different characteristics. However, I suspect that it's marketing, as they won't make the sensors or receivers.Coming from an Artura presentation, the techs guys make clear that it's not possible to fit anything else than the specified Pirelli on that car.
That is not a software thing. The artura uses specific pirrelli tires that have the sensors inside the tire vs attached to the wheel like every other modelI'll try an hypothesis here, but I might be talking nonsense.
It's not clear if the communication uses the existing TPMS comms, extending the existing protocol, or if it's entirely new. I would be surprised if it's not possible to get sensors that are compatible with the McLaren-side hardware and software.That is not a software thing. The artura uses specific pirrelli tires that have the sensors inside the tire vs attached to the wheel like every other model
