Hello from a newcomer to the forum . I have a technical question I was wondering if anyone had the answer to .
It is regarding the brake steer and lack of a limited slip differential .
I understand how the bs can work on the way into a corner , braking the inside rear wheel a touch to assist turn in is very logical . What is less clear is on the way out when you are accelerating , my understanding is the process is used on the way out also ( as confirmed by mcl London just now ) its seems counterproductive to use brakes to aid acceleration but I can let that slide . The confusion is , now that you can turn traction control etc completely off , when you have turned everything off is the brake steer still doing the job of a limited slip differential on the way out or are you in effect now driving a car with an open differential ? Mcl london is looking into it for me , I thought it may be interesting to you all and someone may actually have the answer .
One more thing I presume there is a form of torque vectoring working in combination to the active roll bars and brake steer , can anyone confirm this ?
