1 - 20 of 42 Posts
If anyone is interested.. I'll be able to provide a weight for one of the rears at some point this weekend. I busted one on a pothole a few weeks ago and had to replace it but took the old one back for use as a table or something so I'll put it on a scale at some point before sticking some glass on it....
Surprised if that info is nowhere to be found. I ordered them, despite their looks, for the rotating/unsprung mass issue. Insiders?
I happen to think they are the best looking wheels times 1000. If you don't have ceramic brakes, the other wheels make steel brakes look very tiny.
13.9 kgs for the rim alone can't be right.. The p turbo one was around 10.5 and considered heavy. My damages are around 5.5kgs...
If that's is correct I would try to put a real light wheel on an mp4. When I put dymags on my tt it was as if I improved engine, brakes, suspension in one go. The difference was very impressive..
Sorry for the delay in replying, was an unusually good day here in the UK yesterday so i took the car out for a run...
Reweighed everything again, 13.0 kg for the rim, and that's just the rim with no tyre. My original weight was with the box initially as I couldn't get it on the scale properly without the box and I assumed the box plus some styrofoam would be a lot lighter than when i reweighed it to check.
Would a porsche turbo 20" rim really only weight in at ~10kgs?! wow.
Thats heavy!! But i know they are looking at CF rims for the P1 as an mso option,provided they can get the quality they want and one that is built as a one piece:cool:
I have to admit I didn't initially have any thought whether that was heavy, especially as I vaguely remember someone telling me before that 997 GT3 19 rears were 30lbs or something.
Getting a CF barrel for the P1 rims should already make a big difference without going the full works of a one piece CF wheel surely for purposes of reducing unsprung rotating mass. Although the Agera R seems to have CF rims now so the tech clearly exists I suppose, no reason MSO wouldn't do it as well.
I was told they are 10Kg heavier (over all) than the superlightweights. So that would make around 16.9 Kg for the rears :eek: :confused:
I'll be able to measure the lightweights f/r and superlightweights f/r in a few days. Will post the results here.
Discussion Starter · #20 ·
CF tech has existed for some time, the now defunct Dymag had produced rims with CF hoops. Now HRE is in the process of doing the same, I figured there must be a reason for the delay in mass production of these rims. Which is most probably due to initial costs as well demand for super expensive rims on top of TUV and DOT approvals. Then those of you who are prone to curbing your rims well this could be devastating, to your pocket book and the structural integrating of the rim, hence garbage. I would love to get a set of CF rims for car, the lighter the better. I have a lot of confidence and experience with this technology since my bikes as well all of my rims are made out of CF. Lets get the wheels rolling on these babies, yes this is directed at HRE, I'm anxiously awaiting the ETA for a set. Cheers.....??
1 - 20 of 42 Posts
