Can any one describe life, in an MP12, with exhaust induction removed?
I'm not saying that, exactly. What I mean is that the manual says it only makes a difference in Auto mode. Do you know of any other reference to other parameters being influenced by the Powertrain dial? i.e. throttle response is not mentioned in the Owner's Manual, where I thought it would be.Methinks the switch adjusts a whole host of things to sharpen up the powertrain responses in terms of throttle and shift speeds etc... after all, the 'enhanced' induction feature was added as an afterthought so it's unlikely the switch was originall put there for no reason at all...
I noticed that, too, a couple of days ago when I finished the break-in an started revving to redline. I wasn't sure if it was my imagination, though, so thanks for verifying. I would imagine the throttle response is sharper, too, but strange that it is not mentioned. I'll look for references in other places.I know what you mean but I think there are differences, for example: When in normal powertrain mode the car automatically upshifts rather than allowing you to rev to the limiter, this 'nanny' intervention doesn't happen in sport / track...
Im also sure it sharpens it 6e,but in line with everthing else,if you want to see the real difference go from on exteme to the other!! Set the car in maximum attack,then press winter mode and vice/versa.You will think someone has bolted a lump of lead to your footI noticed that, too, a couple of days ago when I finished the break-in an started revving to redline. I wasn't sure if it was my imagination, though, so thanks for verifying. I would imagine the throttle response is sharper, too, but strange that it is not mentioned. I'll look for references in other places.
