21 - 23 of 23 Posts
Tried this exact one and it constantly falls from the vent. Too bad because I really wanted it to work as it is so simple!
Did you play around with the different ways it could mount? The “vanes” are of two different widths. There is a similar one with two of the “cones” on back, side by side.
I do use two, one above the other, on some of our cars. But need a tall vertical vent.
I would not use this one. I have it and only used it a few times and my vent stopped working. I'm not sure if it was the actual cause but with these cars I would not risk it.
Yes, same here! On the 720s when you pull your phone out of the clamp (hence pull on the vent) the vent machanism breaks very easily and cannot be operated anymore (dashboard has to come off to repair). The middle vent is very fragile on the 720s.
21 - 23 of 23 Posts
