81 - 100 of 103 Posts
O-rings for Turbo oil lines. I was able to get the VAG/AUDI part no 026133557, I/D 17 mm x 2 mm, O-rings for $0.10 cents each at my local auto parts store. I checked the Audi on-line and the price was $6.00 each!!! I got 10-each just in case someone needs a couple. They are green in color and they come from an Audi fuel injector.
Reactions: Anthony D
Thanks, Sean. But still too expensive for my taste.
That they may be, but they're the cheapest you can buy for the car. Stock filters cost more and all others cost more and require oil.
E-0667 K&N REPLACEMENT AIR FILTER $120 for the pair plus shipping/tax
SPECIFICATIONS from the K&N web site
Air Filter ShapeRound Tapered
Filter MaterialCotton Gauze
WashableYes
Flange Inside Diameter3.375 in (86 mm)
Flange Length0.313 in (8 mm)
Flange TypeCentered
Flanges1
Height5.625 in (143 mm)
Base Outside Diameter6 in (152 mm)
Top Outside Diameter5.281 in (134 mm)
Top StyleRubber
Top MaterialNone
Package Contents2 Air Filters
Package Quantity2
Warranty1,000,000 Miles/10 Year
Product StyleRound Tapered Universal Air Filter
Weight3.1 lb (1.4 kg)
Air Filter Large End Diameter6 in (152 mm)
Product Box Height14.5 in (368 mm)
Product Box Length6.31 in (160 mm)
Product Box Width6.31 in (160 mm)
This Product Includes2 Filters
CROSS REFERENCES
BMC FB74208
MClaren 11F0217CP
WashableYes
Flange TypeCentered
Flanges1
Top StyleRubber
Top MaterialNone
Package Quantity2
CROSS REFERENCES
BMC FB74208
MClaren 11F0217CP
To be noted, those are oil filters.
Reactions: rnixon
Frankly, the OEM air filters are cheap compared to many other parts. I'd suggest a Corvette, if you worry about the hundreds of dollars. That's not to dismiss legitimate concern over price gouging, but it's, unfortunately, par for the course on low volume cars.
the Receiver for the TPMS system that resides on top of the plate beneath the transmission is Beru part # F1-100-1222-003.
this is the same that’s on Aston Martins from 04-16’. As such it shares the part #AAD431A166AA
I’ve heard it cross references with a BMW part. Just look for that Beru part# and you’ll find plenty. McLaren wants $800 for this part. I found it for $40.
Asphalt Rectangle Font Road surface Metal
Does everyones 650s have that accumulated oil leak on the left side? my plate looks identical to this. What oil is that?
That’s not my plate. I believe that caught on fire. But when you say left side… are you meaning the passenger side? If you are, you may look at the weep hole. There’s a fix for that if so.
Its my drivers side, left side of the car, on a US car. The tpms mounts to the rear of that plate. My plate looks exactly like this, is there a weep hole in this area? I can't tell but i think its either gearbox fluid or pentosin.
