Try living in a place with temperature swings of -10F to 110F, sometimes dry, and sometimes 95% RH.
You’ll be fine.
You’ll be fine.
The car will be fine......the worst part about living in Florida is the 90-95% humidity and temps hanging around 95+ degrees for 7-8 months a year. That and the traffic! 🤬"curious if I should avoid driving in like 90% humidity in temps around 60 degrees Fahrenheit."
So you won't be coming to visit this summer?I hate being outside when the humidity is 90%
i get irritated
I've found this problem in EVERY environment, humid or not. The least I've seen it effected is spending it's entire life in Montana. SoCal seems to be a bit of a slower pace and it can be humid there. There may be a correlation to how much time in the sun the headlights spend or not though, UV intensity and whatnot.IF it's a 12C, I think the headlights will curse you ....
I THINK they get more moldy, faster, in humid environments.
Remember I leave Mexico in September because so hot and humidThe American Southeast is basically 70% or higher humidity year round, and odds are if it's raining it's 100% humidity no matter where you are.
