I hope that will be the final name! >Apparently, you were right!
http://www.thesupercarblog.com/agera-successor-could-be-named-koenigsegg-ragnarok/
Interesting both the limited numbers and nine gears. I wonder if Koenigsegg is planning to have multiple versions of the 'Ragnarok' or simply have 125 of the same car and that's it. In terms of the gears, it's interesting that CvK decided on nine gears, when talking about the Regera he said his inspiration was to remove all those useless gears that aren't in use at any given time because they're useless weight. I'm guessing here but that transmission has to be a very light (more so than the Agera RS's) gearbox, and 9 gears? is that for efficiency or top speed? Doubt efficiency is Koenigsegg's main concern.According to this article, The Ragnarok will have a different name when it goes into production in the next 2 years. Also it will have a nine speed transmission and they are only building 125 cars and 72 are already spoken for. The article is in swedish so you have use a translator to read it in english.
https://www.di.se/bil/koenigseggs-plan-kora-ifran-lagkonjunkturen/
Do you have the link?Take this with a grain of salt but someone mentioned on instagram that this car will have 1750hp. If this is true this car will absolutely destroy everything out there.
