I will find out for you, when I talk to my buddies at Pfaff, then made it sound like it was fairly easy. They did not mention anything about having to do a wheel alignment. Cheers....??I would like to drop slightly the MP4. I've read no additonal parts are required but how to do it? Are the springs adjustable?
For 15mm does it require allignment?
If you're going to drive lowered, just take them off?I think tex is referring to the rubber air splitters in front of each front tire. Those things really reduce effective ground clearance!
And how did you do that? Can one simply adjust the coilerovers ?.??? Did it require an alignement ?i have my car lowered all the way down and have to problems i guess it all depends on your roads in your area .
For 15mm it probably doesn't require an alignment but one would be recommended with the soft tires these cars come with. Lowering the car 15mm will increase the negative camber and cause the toe to change. It might not be that much of a change but a slight change can cause traction issues along with increasing the tire wear.For 15mm does it require allignment?
i didn't need alignment i check it and was perfect . mp4 doesnt have coil overs its perch system , just lower it to bottom perch front has alot more adjustment than rear does. so don't go all the way down on front or car will look like dragster lol.And how did you do that? Can one simply adjust the coilerovers ?.??? Did it require an alignement ?
From what I've been told you can lower the car approximately .25" which is done by tightening the spring. If the car is dropped by .25" they recommend having an alignment done. All of this information was provided to me by Pfaff Tuning. Cheers....??And how did you do that? Can one simply adjust the coilerovers ?.??? Did it require an alignement ?
It is not for protecting the undertray. It is to split air around the tires for better handling at high speed.Yeah like protecting the under tray!!
Hey thanks, I never took the wheels off to take a look. It seems they are simple adjustable shocks than. For 0,6mm already need for alignment is strange. I don't know any alignment centre can do thatFrom what I've been told you can lower the car approximately .25" which is done by tightening the spring. If the car is dropped by .25" they recommend having an alignment done. All of this information was provided to me by Pfaff Tuning. Cheers....??
Just realized that there was a thread on this matter.From what I've been told you can lower the car approximately .25" which is done by tightening the spring. If the car is dropped by .25" they recommend having an alignment done. All of this information was provided to me by Pfaff Tuning. Cheers....??
RC33 I will contact them right now and try and get you the information you seek. Cheers.....??Just realized that there was a thread on this matter.
Are there any clear instructions on how your technicians did it?
How many turns clockwise or anti-clockwise did they turn specifically on the factory coil-overs to lower by 0.25" ?
RC33 this is a cut and paste from Pfaff McLaren. The perch that supports the spring can be adjust by relocating the circlip on the shock body that locks the spring at its height. Moving the spring perch up will cause the vehicle to lower. This is not available on the new vehicles that have lift mode. Cheers....??Just realized that there was a thread on this matter.
