Hi All,
I've been analyzing McLarenLife posts in pursuit of my next fun car, and collected some observations about reliability I thought the community may enjoy. As a prospective buyer, I always hope these sort of threads exist, but often end up doing the work and posting them myself! [Edit: I bought a 570S and don't regret it one bit. Best vehicle I've ever owned!]
Purpose
Table last updated: 10/18/2020
Take this list for what it's worth-- 50hrs+ research based on issues reported by owners.
If you're a 570S owner and have experienced issues other than these, please reply so the community can continue to document for future prospective owners.
Cheers
Purpose
- Aggregate reliability-related reports from 570S owners since the vehicle's launch
- Post to the forum to aide prospective buyers in their decision making process
- Aide those weighing decision to buy a factory warranty (ESC), or an aftermarket warranty.
- Online forums such as McLaren Life, Youtube documentation, are a reasonably reliable source of owner experiences
- Posters are accurately reporting the issue & solution at hand
- Online forums have a slim % of 570S owners, but are a decent proxy for overall experiences
- 40hrs+ surveying Online Forums, Youtube documentation
- Little mechanic/dealer input
- Contrary to popular belief, the 570S receives few complaints.
- Reliability issues are largely related to electrical gremlins, and mechanically the cars appear to be solid.
- The 570S seems much more reliable than the 12C/650S, and that is becoming more clear now that a decent qty of 570S's have accumulated 20k+ miles.
- Most owners report solid reliability, punctuated only by "ghost in the machine" idiosyncrasies cleared by a stopping the car, letting it sit, then restarting.
- Theoretically, the majority of issues listed below arose during the initial warranty period, and future owners are buying well-sorted cars.
- Compared to the reliability of other marques being cross-shopped in this category (Ferrari 458/488, Huracan, GT3RS, R8 V10), Mclaren is middle of the pack, with a relatively high number of inconvenient issues but far less large mechanical issues.
Rarity | Issue | Cause & fix |
Common | Not starting | Depress brake pedal harder. In rare cases, the brake pedal switch needed to be replaced. |
Common | Key not recognized | Key should be placed closer to Start/Stop button |
Common | Misc dash errors/codes | Mostly "ghost of the machine". Stop/Restart the vehicle, or disconnect battery for 1hr. Sometimes idling for 5min clears codes. |
Fairly common | Windows roll down after door close | Weather stripping may be protruding, causing window to drop for safety measures. Re-seat the weather stripping. |
Fairly common | Miscellaneous door latch | If the car is spec'd with "soft close" doors, the latch mechanism from Tesla likely failed |
Fairly common | Comfort entry not working | Battery reset, sometimes a reflash |
Fairly common | Battery dying quickly, causing issues | Key is left too close when vehicle not in use. Constant communication drains the battery. |
Fairly common | Headlight condensation | Occurs after rain driving or deep cleaning. Let sit and it disappears. |
Fairly common | Windshield stress cracks | Happens early, and the dealer needs to use a more flexible sealant. May be accelerated by poor design of frame around windshield. About $2300 to replace |
Somewhat common | IRIS (interface) errors | Majority are remedied with reset (done yourself). Software updates have fixed many issues. Requires dealer to update. |
Somewhat common | Coolant tank leaks | Cracked coolant tanks, or loose/bad clamps on hose near tank. Cause is the tank's proximity to air/water intercoolers and exhaust cause expansion and decrease hose longevity. Could be amplified by aftermarket exhausts with lesser heat protection. |
Somewhat common | Locked out of car | Variety of causes: bad latch, poor signal, low car battery |
Somewhat common | Small panels falling off | Double-sided tape and adhesive failures. Simple reattach. |
Somewhat common | Oil-related error/s due to oil filler cap not fully tightened | Oil filler cap not fully tightened |
Somewhat common | Panel misalignments from factory | Build quality. Doors can be adjusted, but likely at cost of fitment elsewhere |
Not common | Light rattle from the engine bay | Heatshield clamp bolts loosened, possible tab on catalytic converter mount snapped |
Not common | Fender liner becoming detached | Reattach |
Not common | Part of front bumper flying off at speed | Incorrect re-installation of part. E.g. the professional applying paint protection film (PPF) |
Not common | A/C blowing hot air | Unconfirmed. Stop/restart vehicle. |
Not common | Rear parking brake error | Unclear fix -- may be reset by stop/restart |
Not common | Paint bubbling | Corrosion on Aluminum - must repaint the panel. 5 year corrosion warranty from McLaren. Most popular on 2016's |
Not common | Rear diffuser separating | Failure of adhesive. Clean surface then dab silicone adhesive behind fins |
Very rare | Transmission oil leak | Failure of basic o-ring, small but annoying job |
Very rare | Oil leak by variable cam timing harness | Due to leaky o-rings on the filter's plastic housing. Replace o-ring's likely fine, whole housing as precaution. |
Cheers
