1 - 17 of 17 Posts
570S Silica White
For those of you who have tracked at Laguna in your 570S: I have a 92db day coming up, where does the 570S with sport exhaust come in on the meter? Is it a lift and short shift situation, or can I hammer it past the sound station?
I would second shardul's comment. Sport exhaust is over 100db at high revs. You may want to "lift" as you approach and go by.
As for the 127db figure, that sounds really high for sports exhaust. I know b/c I was at 110db (5000 RPM) with custom exhaust and sport cats.
127 DB sounds VERY loud to me.
Every 10 DB increase gives a 10X increase in Sound Intensity, and a 2X Perceived Loudness.
So, from 100 DB to 120 Db, the Sound Intensity is 100X, and the Perceived Loudness is 4X as loud.
It's tough at Laguna to beat the system, as the Measuring booth is out of turn 5, accelerating uphill.
I run a 12c with stock exhaust and pass 92db without lifting. 127db is like a fighter jet at full throttle. Like 3000x more intense.
I had to lift AND be in fifth gear to pass at Laguna. My buddy that shared my car with me lifted but stayed in fourth and got us booted from the track. 92 dB day. Good luck.
Kurt
There has been an uptick in meatball flags at Laguna Seca in the last year.
They give 2.4 decibel leeway from whatever the sound restriction is that day. Basically you have 94.4 db before you get flagged on a 92 db day.
What seems to have changed is that 2.4 db leeway ever since Weathertech took over the sponsorship of the track. There just seems to be many more meatball flags then what was in the past.
You'll probably be able to pass on a 92 db day... as long as you don't downshift under the bridge (before or just after and it doesn't echo), and do not create the backfire with the upshift right around the sound station. You might just want to take turn 5 in fourth gear so that you don't create the backfire.
The county owns that track and they have been getting noise complaints from the locals. I know I know, the track was there first but it doesn’t matter at this point. The county is cracking down and we just have to adjust.
Soooo frustrating.
These days I just search for the >100 (or unlimited) dB days at Seca. I’ve actually kept the stock exhaust on my Gen IV ACR just because of the restrictions at Laguna Seca... it’ll go max 92 dB up the hill on a normal day.
On the plus side, those high dB days are like a reunion of all your racecar buds. Some of my favorite track memories are from running with serious fast/loud cars in the group...
Rich
I dont know if it still works this way but there were a certain number of days/events at certain dB limits. Only About 5 weekends at 102. A few at 96 or so. Lots at 92. One year we (bmws) were racing with Porsche club on 92dB. They vowed to get a 102 weekend—just need to triple the entry fees to cover the extra $50k rental !
I think the Hooked on Driving group has a high dB coming soon. Check their website.
Hooked on driving on 06/12 is a half day event
Fast toys is open track (no run groups). Mainly novices. Passing (point by or no point by) is only on front straight to bridge before turn 1, turn 4 to 5 and 5 to 6. Not a good idea to go unless you are a novice or intermediate driver.
Good to know. Thanks.
Pretty sure you can get a db meter app for your smart phone to get some idea of noise at WOT. That being said go through one gear higher, or short shift. Not as much fun, alas with the shape of the pipes you can't fabricate a turn down pipe that would redirect the exhaust.
1 - 17 of 17 Posts
