Surely it is only the tread width that is different ie 315 v 305, I would not have thought this would affect anything tires do not run that near he archesI'm about to order a set of Toyo R888 tires for track duty and I was wondering if it's OK to run non-stock size rear tires. The front tires have exact same size as stock P-zeros (235/35ZR-19) but the rear is 315/30ZR-20 vs stock 305/30ZR-20. Does anyone know if this will throw any codes or affect driving dynamics since it has slightly larger overall diameter?
Thanks,
Gregory
Hope it's insignificant and won't cause any issues i.e. check engine light.Gregory
10mm wider section on a 30- series profile means that the radius of the tire will increase by less than one-eighth of an inch, i.e. Insignificant and not a problem. Your speedo will now be 3% slow tho'!
Great!!! In fact, I just ordered same HRE P44SC wheels in different finish.dont worry bout it... its already been fitted on there...
So if you went with a 235/30/20 and 20" up on the front, which has an overall diameter of 25.55 vs factory 25.48, the speed down from 791 rev per mile factory to 789 rev per mile while retaining a 305/30r20 there would be little to no change. I guess it would only mean the window of that traction control parameter would only be if that speed difference exceeds beyond 5 revs per mile?only time it would become an issue is if the speed difference between the front and rear wheels falls out side the parameters set up in the traction control system window. Steering angle input also has and effect on this calculation, but as long as everything stays within the pre-determined envelope you will be fine.
so how did it go with the Toyo R888 315? I am getting them tomorrow.Surely it is only the tread width that is different ie 315 v 305, I would not have thought this would affect anything tires do not run that near he arches
Let us all know how they compare to stock tyres, talking to a test river at Castle Combe and he said if Michelin do a PS2 to fit he would try them over the Pirelli
