1 - 16 of 16 Posts
Here is a (new to me) reset procedure. We all know you can just hold down the volume dial for 5-10 seconds to reboot IRIS. I'm not sure how this reset is different. I was told to try this when the volume dial reset doesnt work, so I presume it's like a really cold reboot.
Anyway, the process is as follows:
(A) Press and hold the IRIS mute button and perform the following actions by turning the volume control ring (B):
Right two notches
Left one notch
Right one notch
Left three notches
Right one notch
Tried it and Space Invaders came up. Brilliant retro and fun. What a car company this is!
Right two notches
Left one notch
Right one notch
Left three notches
Right one notch
This is funny, but is this for real?!? (C=
Funny thing, I had to call matt at mclaren philly yesterday. All of the sudden while driving, iris stopped responding. Even if I shut down the car, iris was still stuck and wouldnt go off.
I was told to hold down the round volume dial afew seconds.
Good to know that I can hold down the volume dial to reboot. Can this be done while driving as well? Sucks to have to pull over.
I asked if there was a fix for this problem, they said no, i said maybe a new iris 2.0 and chuckled (C= Doesnt hurt to ask. Unfortunately, "NO" was the answer. heheh.
lc
'Holding the volume knob down to re-boot' ....... You guys should have read your manual; it's all there!! :p
Limey,
I did, but my manual keeps falling apart the more I read. All the pages are coming apart!
I have probably half the pages loose )C=
I didnt even realize there was a reboot or had to reboot a car audio/nav system. Never had this problem in any other cars before so didnt think to look in the falling pages of a manual I have.
Also, i was in the middle of the drive when this happened. Manual is in my house. No glove compartment except for the front under the hood storage.
lc
Discussion Starter · #8 ·
Calvin, holding the volume dial in will reboot. And probably what you should use in the first instance if/when IRIS locks up. And no problem doing that while you drive.
I was told the above is an even more sever reboot for when the normal volume dial reboot doesnt work. I would not recommend doing that safe-cracking sequence while driving! :)
And yes, it's for real.
Limey,
lc
Calvin,
Regarding the glove compartment: There is a small clip underneath the dash (passenger's side airbag) where the (3) McLaren mini-guides slip into. :)
Calvin,
THIS i didnt know about!. Should of read the manual (C=
thx Limey
Limey,
lc
Actually had this problem a ton of times in my Audi S8 3 years ago.
Calvin,
I tried that.. I am clearly too stupid to do so, unless they are supposed to half hang out and flap around while driving... :)
1 - 16 of 16 Posts
