1 - 20 of 43 Posts
Hi guys, just wanted to show pictures of my new exhaust I got for my 570. It was made by Top Speed Performance, it is the "cheapest" titanium exhaust you can get for the 570 from all the research I did, $2,100 to be exact. Right before ordering it, I asked them if they made the "blue titanium" look on their exhaust. They said that they had never done it on a 570 exhaust before but would give it a shot on mine if I wanted to be their test dummy. They sent a couple pictures halfway through the manufacturing process of building it to make sure I liked the blue titanium look. For a little over $2k, I don't see how you could get a better blue titanium exhaust for a 570! Will have it installed on the car this weekend.
IMG_4099 by keaton wynn, on Flickr
IMG_4098 by keaton wynn, on Flickr
IMG_4095 by keaton wynn, on Flickr
F0725FFD-C853-4455-9340-AB51AC44B6C8 by keaton wynn, on Flickr
After install wipe down with WD40 and then rub off/dry the WD40 with a clean microfiber. If you don't, any fingerprints from handling during the install will burn into it. It will smoke some at first startup but it will go away.
Also, uncovered/head-shielded exhausts scare me as I don't want to burn my car down lol.
Thanks for the WD40 install advice! I will make sure to do that. And I know many 570's that are running no heat shielded exhausts and none to my knowledge have any problems with heat! If anything taking out the big stock exhaust will help keep things cooler in the back of the car! Frees up a good amount of space getting rid of the stocker.
It looks great. Is the blueing kinda visible from the outside as you peek through the rear vents and gaps?
I have the same exhaust. Great exhaust for the money. I've got a regular titanium for $1900 but it turned into a beautiful blueish titanium after few hard runs and flame shoot revs.
Here is a pic of how mine looks.
198662
Discussion Starter #7
That looks great! Thats pretty cool how it turned blue naturally like that. Any problems with no heat shields??
Second on the no heat shield question! Maybe the down pipes are more sensitive to that than the exhaust.
IMG_4099 par keaton wynn , sur Flickr
IMG_4098 par keaton wynn , sur Flickr
IMG_4095 par keaton wynn , sur Flickr
F0725FFD-C853-4455-9340-AB51AC44B6C8 par keaton wynn , sur Flickr
[/CITATION]
DO YOU HAVE A VIDEO OF THE ENGINE RUNNING?
WHAT EXHAUST AT THE TIME OF PURCHASE?
Discussion Starter #17
Did you use the OEM clamps to mate this system to the downpipes and tail pipes?
The instructions say to use the OEM clamps! Have not installed it yet but will give an update with pictures when I do!
Yes, it uses stock clamps to mate downpipes and tail pipes.
Install tip for OP: Tail pipes are slip on and they are little too tight. Get this loaner tool from Pepboys or Autozone before installing.
Good luck!
1 - 20 of 43 Posts
