1 - 20 of 50 Posts
Discussion Starter · #8 ·
I don't get any snow but can you explain why Epoxy and Snow don't work.
The other thought is to just stain the concrete but Epoxy will help reduce noise and dust.
Mine is epoxy with multiple color chips distributed throughout for grip and aesthetics. Sort of a mocha/black/white theme. It's definitely not slippery and cleans up nicely. Many color options. I do notice it is a tad harder to sweep but it is extremely resistant to corrosive fluids.
I am going to throw my 2 cents in. I am in the business and manufacture floor coatings for concrete, along with about 1400 other products for the concrete industry.
I am including a few pictures of my garage floor.
To start it all depends on what you are looking for? Showroom looks, Durability, ease of Maintenance, etc....
There are a lot of products out there, some for DYI'rs and some for Professional applications.
The DIY products are typically formulated to be easy to apply. So they compromise on the durability to do this.
Not to promote my own products, but as a car guy I formulated what I thought was the best product for garages. The product we manufacture is a PolyHydroxy compound which is designed to resist everything ( battery acid, brake fluid, Gearbox fluid etc...) basically anything that a car can leak. The product is impenetrable. So your concrete floor maintains its look without any stains, and has a glass like finish. Fluids just sit on the surface and are easily wiped up with a paper towel.
The downside is that if you get snow on it and the concrete is smooth you will end up flat on your ass pretty fast or at a minimum look like Bambi on ice. I know as I have ended up on my ass a few times.You can add silica sand to the sealer to provide abrasive anti slip so this is correctable. To get the best look, the floor should be new without any stains or oil spots, the product will cover oil stains but the finish is not perfect. Also there should not be any sealer already on the floor that would prevent the sealer from penetrating, this goes for any product.
Here are a few pictures of my floor, these are not retouched in anyway. and I have added the brochure. The product is called Durmax, it is a 2 part product, moisture cure,
The concrete itself is integrally colored Buff with highlights of Brown added during troweling.
Have to say Zach that is the most impressive natural concrete finish I've ever seen,unfortunatly my ass is too skinny to risk the impending impact ,but still its looks too good to be real :)
Zach,
for a commercial building such as service area of a dealership, what would you rate Stonhard product vs automotive grade tile?
If you damage a tile it is relatively easy to replace, just keep extra tiles around. I am not personally familiar with the stonhard product, but repairing coatings is easy but the appearance of the repair is obvious.
How does this hold up in a working garage with jack stands, metal-wheeled jacks and engine hoists, dropped parts and tools? Cost per squared foot?
The durability is very dependant on what is below the product. If the floor has been previously sealed and you are applying on top of another coating then there is a risk of de-lamination.
When the product is applied to a virgin surface, it becomes part of the substrate. That being said anything that would damage the concrete will damage any coating.
Cost is very reasonable. the product cost per square foot is below $0.50 material only.
Did you have to cut any tiles? My garage has several recessed areas and I'll need to rent a table saw, wondering if you have experience with this?
I think Race Deck lets you submit your floor dimensions and they ship you what you need to minimize the need for cutting. I doubt any of the floor tile installs can be done without some cutting though. Always seemed like it would be a real pain to me, and I was never confident the edges would look clean.
Would love to hear from someone who has done it themselves.
1 - 20 of 50 Posts
