1 - 10 of 10 Posts
it's a secret out loud
the cam pahsers or camera variators of the mclaren platform p11 of the first years
they have a bad design, producing a failure when returning to the position causing the crankshaft to be in the wrong position
This causes the flashing yellow light to fire, especially at low speed or when maneuvering in a parking lot.
sometimes produces weak engine starts and a cold valve rattle sound for only a few seconds
over time it is possibly a time bomb
repair it and change it to the updated part number much stronger without failure
It is very expensive (you have to lower the engine and open it)
I would like to gather in this thread all the information available on this general failure not recognized by mclaren
if there is an alternative to "bite the bullet" if someone has solved it or believes that their car has had a fault.
the price in a famous independent workshop
is 1k per phase variator (x4) two on each motor bank
intake and exhaust
204627
according to an image published by a mclaren dealer
mclaren cam phasers are made by carraro a famous italian company
in accordance with this thread and with the opinions of ima2nr with whom he has spoken about this several times
you will not be able to tell if the phaser is failing except for the flashing engine light at very low speed (parking maneuver, traffic light)
the car makes no strange noise, no power loss
the only symptoms are a high fuel consumption and when the engine is started cold a rattle that lasts very little (half a second)
my question is
the breakdown will get worse with the passage of time and kilometers?
will it become a time bomb ??
I think I may live with a position fault when starting the engine or a flashing light coming and going
(or maybe repair it and spend 25k$)
The cam phaser has a set of springs that compress as the engine revs increase and allow the camshaft to change timing, that is provide variable valve timing over the rev range to improve engine performance drivability.
My understanding is that some of the early 12C motors experienced spring fatigue (failure). First a softening of the spring tension and finally a complete spring failure.
Discussion Starter #7
an image of a pier
of a camera phase variator
204628
this defective spring prevents it from returning to the original position
If I am not mistaken, this part is in charge of varying the angle of the camshaft with May or less crossing (depending on the rpm) with respect to the crankshaft.
this wrong position can end up destroying the engine?
Yes-if the spring breaks then the valve timing for that camshaft would not be optimized. I don’t know if the timing would be so bad as to allow interference between the piston crown and a valve though.
Discussion Starter #9
this is my existential doubt
my opinion is that this spring can lose tension but it is very very difficult for it to split or break
There are hard stops to prevent cam from going to far as to cause valve piston interference.
The spring only brings back cam to startup position and engine oil pressure moves the cam as needed.
1 - 10 of 10 Posts
