1 - 5 of 5 Posts
Sponsor
It’s finally here! This past weekend Fabspeed Motorsport opened its doors to a gorgeous Rosso Mars Huracan. When the weather dramatically changed to Spring temperatures yesterday it was the PERFECT chance to get the car outside and do a photo shoot before the car was put up in the air on the lift for the development to begin.
Stay tuned for more information!
Sponsor
Here are the details for the the Valved Supersport X-Pipe Exhaust for the Huracan!
The valve functionality is controlled via the factory “Anima” switch located on the bottom of the steering wheel which controls a wide array of vehicle dynamics, including transmission behavior, steering and suspension settings, stability control and more. It has the following modes:
STRADA: Transmission shifts automatically for optimal fuel efficiency, suspension on full soft, stability control on, and the exhaust valves are closed from 0-4200 RPM.
SPORT:Transmission shifts automatically at higher RPM for sportier driving, suspension stiffens, stability control is less intrusive, and the exhaust valves open more freely under heavy throttle application.
CORSA:Transmissions is shifted manually, suspension at full stiffness, stability control off, exhaust valves locked open.
Maximum power gains of +29whp and +19 ft/lbs of torque are seen at 8000 RPM. Peak power is increased to 584whp and 420ft/lbs of torque.
Fabspeed system saves 23lbs, which is a 35% weight reduction vs. the factory muffler. (Factory = 66lbs, Fabspeed = 43lbs)
Lamborghini Huracan LP610-4 Valved Supersport X-Pipe Exhaust
1 - 5 of 5 Posts
