1 - 7 of 7 Posts
Sponsor
Take your 570S to a completely new level of power and excitement with approximately 700 horsepower on tap by upgrading the exhaust, catalytic converters, and ECU tuning parameters. Includes Fabspeed's exclusive Bolt-On Tips for more aggressive styling.
209686
209498
TRIM LEVELS
The Street Performance Package comes with the following products:
McLaren 570S / 570GT / 540C Sport Catalytic Converters
McLaren 570S / 570GT / 540C Supersport X-Pipe Rear Exhaust
McLaren 570S / 570GT / 540C Deluxe Bolt-On Dual Titanium Tips
McLaren 570S / 570GT / 540C Fabspeed ECU Tune
FEATURES
  • Fits all McLaren 570S / 570GT / 540C vehicles
  • Supersport X-Pipe improves power and throttle response while reducing weight by 8lbs and adding true hypercar-worthy exhaust sound
    • Factory Exhaust: 22lbs / 10kg
    • Fabspeed X-Pipe: 14lbs / 6.4kg
  • Fabspeed's Catbypass Pipes replace the restrictive factory catalytic converters with much less restrictive straight-through pipes for maximum flow and performance. Less restriction after the turbo allows for faster spooling, boost response, and a crisp sports car sound with maximum turbo noise.
  • Fabspeed's optional Sport Cats are constructed with Fabspeed-proprietary HJS German-imported high-flowing catalytic converters using T304L stainless steel. These cats have been designed by HJS and specifically optimized for the McLaren for maximum performance with NO check engine light, guaranteed
  • All Fabspeed performance products are backed by the Fabspeed Lifetime Warranty
Sponsor
Discussion Starter · #2 ·
Check out our 600lt Style Valved Exhaust for the 570/540/GT
Unleash a new level of aggressive styling and sound with Fabspeed's McLaren Valvetronic Sport Catalytic Converter Exhaust System complete with revolutionary 918-style top exit exhaust tips. Fabspeed's valved design allows you to uncork the full roar of the 3.8L twin turbo McLaren engine, but still gives you the ability to return to a more moderate level for cruising through the neighborhood by simply closing the valves.
FEATURES:
  • Fits all McLaren 570S / 540C coupe models (NOTE: This product is not compatible with convertible models at this time.)
  • Designed to fit with the factory/OEM McLaren exhaust or any aftermarket exhaust that is designed to fit like stock
  • Includes rear deck conversion kit for the top-exit "918-Style" exhaust outlets
  • Increases power and throttle response
  • Dual exhaust tones provided via a vacuum-actuated valve while maintaining factory functionality
  • Constructed from high quality 14-16ga CNC mandrel-bent T304 stainless steel for maximum performance and durability
  • Optimized for maximum performance with NO check engine light, guaranteed
  • Direct replacement for the OEM muffler with no welding required
  • Re-use OEM secondary cat heat shield; Requires minor trimming to fit - use supplied template as a guide.
  • Includes Fabspeed valve controller kit with two (2) key fobs.
209809
209810
Sponsor
Here is a session on our development 570S on our Dynojet. We're working on crafting an exhaust suite with several options for the rear exhaust, as well as HJS catalyst-equipped downpipes and Catbypass Pipes. Our tuner will be proving the performance of all our products as well as dialing in a performance ECU Tune.
Sponsor
Discussion Starter · #5 ·
For anyone that's on the fence about any of our Mclaren systems, now is your chance!
Wanted to award the community with a 10% off discount before we launch our holiday promo this weekend.
Shoot me an Email - [email protected] - and I will get you set up!
214538
1 - 7 of 7 Posts
