I just wanted to add something to the collective knowledge in case it came up again.
Recently I had a buzz/rattle coming from the dashboard near the driver's side. I turned off AC/fans/ etc. etc. to try and isolate. I also drove in hot/cold fast/slow etc. Most prominent at 40 plus MPH, but otherwise consistent.
Their is apparently a spring in the steering column that is used to help adjust the wheel. Apparently this spring can under the right circumstances vibrate and buzz. The dealer went in and put some "insulation" around it and the noise has 100% stopped.
I hope this helps someone else if the same symptoms occur.
