Hi Folks,
I took a bit of a plunge and installed the SportContact 7's to replace the stock Pzero's after seeing the possitive reviews and getting a possitive recommendations from CoOrdSport in Holland (thanks for all the help!). I was initially planning to get a set of PS4S's but thought they were worth the try as they are also significantly cheaper than the Michelin's. I thought I'd share my experience as I've not seen anything on the forum about these tires yet. Now I'm no track rat, so drive the car spiritely on the road and may go to the track once or twice a year. But irrespectively thought my experience after the first week of testing the tires out might be useful.
So as with many, these tires are quite a bit wider (I didn't measure but eyeballed..) than the stock Pirelli's:
Front (a little wider, approx 10mm's):
Rear (a lot wider, approax 20-30mm):
As you can clearly see the blocks on the Conti's are noticeably bigger than the Pirelli's, especially on the rears. New thread depth is about 6.6mm (that I actually measured) and my pirelli's where at about 6.1mm when taken off.
So my experience is that they are much more comfortable and softer than the Pirelli's and have much much better grip at the same temperature. When cold (around 20/68 degrees C/F) the Cont's spin a lot less and hook up a gear or two lower than the Pirelli's. When warm (35/95 degrees C/F) and doing a launch the Pirelli's always spin while the Conti's actually hook up from standstil (First time I experienced it! and I managed to do a 2.88 sec 0-100 kph on a random road I usually do my launches on). First time I've ever gotten under 3 seconds! And as the tires were at 35/95 degrees there is probably more in the tank!
I did hit some "higher speeds" and the Conti's felt very stable and when I slammed the brake from there it was rock solid as well. So all-in-all I'm very positive so far and can recommend folks giving them a try as an alternative to a PS4S. When we get some rain I'll try them out there as well and report back as these are supposed to be very good when wet.
