Both cars struggle with traction, the power is just huge on both. As others write here it is more a matter of tires at 0-100 than 650S/720S. I drive the Trofeo R on both, both slam into the back about the same, shoot off and permanently struggle with traction (you say dem swim). At the rolling start, or accelerating in the third gear for example, the 720S is then already superior, it simply has again significantly more power.Today I got four new tyres and I tested the 650 spider intensive on the German motorway.
However, I have to say that from zero to 100 in sport mode, this swimming response from the back to the front or even from the sides - called direct steering - somehow takes a lot of getting used to and I always equate it with insecurity on the part of the car.
It's certainly exciting, but can't it do better?
How about the 720 is this different from 0 to 100?
@Iron5 - because you own both and you like both I will get an honest advice from your side. So is the 720 not swimming so much from 0-100?
thanks for all of your thoughts
As already written, both are brutally fast and are capable of overtaxing their driver very quickly. I would never push the accelerator pedal hard on either as long as the steering wheel is not pointing straight ahead. Too quickly the rear axle is broken out with both...
