6e,i think you mis- read the artical,it dosent say you cannot retro-fit the lift system,it just mentions that it will not be part of the free of charge retro-fit
Good point!!6e,i think you mis- read the artical,it dosent say you cannot retro-fit the lift system,it just mentions that it will not be part of the free of charge retro-fit![]()
That's odd; I would assume that (if in 'track' mode) the car would do the opposite and hunker down a bit. I wonder why it lifts instead ?You should note that when stopped, if you switch the suspension into track mode, the nose does lift - I've used this for speed bumps. So this lift option very well could be software based and offered to us!
Gallardo says new wheels too and don't forget Bluetooth with the IRIS.That's odd; I would assume that (if in 'track' mode) the car would do the opposite and hunker down a bit. I wonder why it lifts instead ?
So from what I've now gleaned, the major changes for the 2013MY will be:
• a power increase of ~25hp / with revised transmission programming
• the availability to pop open the passenger door with the key fob
• an operational navigation system
• a new color (yellow)
• a selectable cabin engine sound function
• an optional lift system
• a price increase
Do I have all this straight?![]()
A little birdie told me, they may just fit a membrane (switch) pad into the doors replacing the somewhat tricky swipe mechanism.Gallardo says new wheels too and don't forget Bluetooth with the IRIS.![]()
I hope not!! Mine works perfectly now. Too perfect. Goddamit this car has no soul!A little birdie told me, they may just fit a membrane (switch) pad into the doors replacing the somewhat tricky swipe mechanism.![]()
I think you mean in normal mode it raises or track mode it lowers.You should note that when stopped, if you switch the suspension into track mode, the nose does lift - I've used this for speed bumps. So this lift option very well could be software based and offered to us!
A no charge lifting system; you can't beat that deal!No, I mean what I said. From a stop, if you put the car in track mode, it will lift the nose. It hunkers down again over 10-15mph.
It's not intended to be a lift system.10-15MPH?? What the?
So when I do 15MPH over a speed bump, Im screwed, and then when Im in traffic I have to come to a complete stop to go over? That sucks.
Trying to reuse that control switch due to a lack of buttons on the console is not good. I'll think of a better way to do it. Who knows Ron?
