1 - 8 of 8 Posts
Vendor
Caliper Bleeder Valve Cap
OE vs. RB
RB caps are made to fit standard M10x1.0 bleeder valves (Non AP), they are not the same as OE but are fully compatible, very strong & durable also easier to "CAP" to the valve than OE as you don't need to align the hex orientation like OE.
Vendor
Vendor
Rotor Replacement:
Upgrade to RB-CCB
570S (650S, 675LT, MP-12C)
720S (600LT, 765LT)
Downgrade to iron rotors
720S (600LT, 765LT)
Vendor
Discussion Starter · #8 · (Edited)
McLaren caliper rebuilt kit is now available for ordering & shipping (Piston in mid Dec.)
Join thousands of other car enthusiasts (street and track) to improve OE (Brembo or AP) calipers' performance and durability by replacing the OE components to RB.
Unlike what you have learned, RB's high temperature (blue) boots "never" got burnt out. They can safe guard and protect your inner piston & oil seal from heat and foreign debris and preserve not only the calipers' original functionality but prolong the service life itself and other associated components (pad, rotor).
RB's HT dust boots is an icon in the performance brake industry to have changed the conventional wisdom/advice of "don't bother" installing a dust boot for race cars, because they got burnt/worn out quickly.
It's our pleasure to make the performance industry most trusted caliper rebuilt kits available for non-metric piston (AP / McLaren) calipers. Better yet we have a very user friendly ordering system, simply identifying your calipers and click the red links will get you to the components options (No VIN, Year, Models or Kit# are needed):
BS = Boots* and Seals kit
BSP = Boots, Seal, Pistons kit (Save 10% on bundle vs. purchase separately)
P = Pistons
*Only high temperature boots are made available, and due to the nature of boot material (Silicon) when installing must make sure "No Contact" with brake fluids and/or brake grease.
Fitment is certified, performance improvement and durability are fully guaranteed.
1 - 8 of 8 Posts
