Has anyone considered using a Braille battery in there Mac or any other high performance car. If so what are your thoughts, is there one in particular that you would use over another? Cheers.....??
Hey nielsll yes I realize that the car comes with lithium ion battery, I'm just looking at ways to reduce weight in the car. I know it sounds insane, and I could always trim some weight off of my person, but I am a little nuts. Do you know what the current specs are on the Mac battery? Cheers.....??We already have lithium ion. Do you need a replacement? It should still be under warranty.
Will let you try this Ken,is it just the weight or are you partially sighted?Well I'll have to find out what the guys at Pfaff Tuning have to say, or should I say Terrance. They'll probably think I'm nuts, which is partially true. LMFAO����. Cheers....����
Yes indeed andy I am partially sighted, near sighted that is. LOL??. Cheers....??Will let you try this Ken,is it just the weight or are you partially sighted?and need to find it in the dark!
McDc I will tread very lightly, no pun intended on this issue, currently waiting on input from the powers that be. Cheers....??You could only save weight by replacing the Mac's Li Io battery with one that has a smaller capacity. I would strongly suggest to not do so as the factory supplied is already on the very low side in terms of capacity.
It's was just a thought and from the sounds of it not a viable one at this point and time. As previously mentioned I should just go on a diet which will save me a ton of money. LOL??. Cheers....??Considering the 12C's battery only weighs 8 pounds as it stands, saving 40 is going to be extremely difficult (and would result in fron-tend lift). I'm certain that 40lb savings is compared to a standard wet-cell battery. Has anyone here seen the 12C Battery? I bet even if you have, you haven't. The thing that looks like a standard car battery is actually a case containing the Li battery. They used a standard housing so that if you were ever stranded anywhere, you could fit a standard battery to get home.
That's what I do before I go out for my bike ride, ever ounce counts. ??I often tell people: "use the restroom before hitting the track!"
