1 - 15 of 15 Posts
Hello,
My battery keeps going low: the days indicator gets lower, at a higher rate than the actual days. Eg it shows 21 days, one week later it's 5 days. All this despite the car being plugged into the OEM trickle charger. Even weirder than that, the charger always has the green LED to indicate full charge.
I've tried keeping the car locked, keeping it unlocked, keeping it locked with the key away from the car, etc.
The car is always able to start though.
Last time I drove it the battery started at 10-15% and then it went to 43% gradually, and then suddenly jumped to 100%. During that time I got multiple "battery management active" warnings. Then when I restarted the car, those disappeared.
Just bought the car a few months ago, only drove it 4-5 times, taking it to the nearest dealer soon (that would be Italy) - hopefully they'll be able to shed some light about whether this is a symptom of something, but in the meanwhile - has anyone here experienced the same?
· Premium Member
2019 720S Coupe Track Pack
Only 4-5 drives in a couple of months?
You need to drive it more - do a good couple of hours drive if it's stood a while if you can find the time. That's what they are for :cool:
Reactions: invisiblewave
· Premium Member
Hello,
Anytime you need someone to drive it for you so it gets more exercise I am available… Just sayin’
Discussion Starter · #9 ·
Rest assured, the car is driven 😅
It hasn't been in my possetion for a while cause I sent it to Germany to get the suspension accumulators replaced, and I had the battery issue right before sending it. It's on it's way back now and I got a CTEK charger so let's see
You are using the 12v socket in the frunk?
Sometimes if someone removed the frunk tubs the wires can get disconnected.
or maybe the 12v plug is not installed correctly?
Discussion Starter · #11 ·
ah that's a brilliant point
I am using this socket but once I pulled it and the whole panel just detached itself and remained in my hand. I did check for loose connections though.. it looked OK but once I have the car I'll check again.
Any alternatives?
actually ignore that - the charger LEDs actually change when it's connected to the battery so this theory can be discarded
When the charger first cycles, it should always show a low battery, then eventually the LED shows full. If it starts out of full, something is off. Maybe power cycle the charger itself and make sure everything is seated correctly. If not try another charger.
· Super Moderator
“I’m a Tuner”
Kevin P
770-284-0172
Kennesaw GA
1 - 15 of 15 Posts
