I think that if Aston would have used the same lightweight materials (adjusted for the strength needed for the higher downforce of course) that T50 uses the Valkyrie would be a decent chunk lighter.This is getting a bit technical, but I don't think they could get to 900kg with the changes you suggested. The luggage space on the T.50 is basically free, it's an empty space that they introduced an opening to, and so the only added weight there is pretty much the rubber seals around the opening. Making it a two seater would shrink the canopy a bit, but that might net a few kg at best. In fact, making it a two seater might actually make the car heavier because you would have to increase the wheelbase so that there is enough space for the pedals without introducing offsets (which is what happened on the T.33). You could move the water radiators from the front and put them to where the luggage space is and that would cut a few kg, but only that because you are just talking some piping. The T.50 is already pretty cut to the bone so finding any weight would be pretty hard. I think that the most you could save would probably be on the interior and sound proofing and then on exterior panels if you made them a lot thinner. That's basically what they did on the T.50S which is supposed to be 852kg.
In any case I kinda lost track of what's really being discussed here. Yeah, maybe you could make a 900kg T.50, but although that might have a comparable ergonomics to the Valkyrie, nothing else would be comparable, so you still can't really say that it should be possible for the Valkyrie to be much lighter. I already gave an example with the more powerful engine making the car much heavier, but it's other stuff as well. For example, the highest weight with all the downforce the T.50 experiences is 1046+75+322=1443kg. For the Valkyrie it's 1392+75+1400=2867kg. So, now the wheels, the hubs, the bearings, the upright, the connecting arms, the spring and the damper all have to be twice as strong! Because of how geometry works out that doesn't necessarily mean they have to be twice as heavy, but still, significantly heavier! Another problem is that the Valkyrie is very stiffly sprung and your chassis stiffness needs to match that. So where the T.50 can get away with "just" 27000Nm/mm, the Valkyrie might have to be 2-3x as stiff! Which, again, means the chassis needs to be made much heavier. And, also, the wheelbase is longer, so the distance between front and rear suspension pick up points is longer, so you need to make the chassis heavier still to get to that increased stiffness number! And this just goes on and on. Power, downforce, size, all big enemies of light weight!
the brilliance of the t50 is the fans ability to reduce downforce at high speeds.
And didnt aston claim that the lack of a reverse gear counters the weight from the hybrid system
So the Senna with a heavy 3.8l turbo engine (turbos are heavy), a heavy double clutch gearbox vs a single clutch no reverse gearbox, bigger wings, a bigger car in general, decent amount of downfoce, fairly regular rims compared to the GBP48k magnesium rims on the Valkyrie is still lighter than the Valkyrie.
yes i know the 6.5l V12 is heavier but still
and the weight we are comparing, actual customer weights of a Senna vs Astons claimed weight of the Valkyrie,
there is a clear weight/cost tradeoff for parts (titanium anyone), and Aston has mostly chosen pig iron wherever they can
i will put my Senna and Valkyrie on the scales later thisyear...
