Just a heads up that Assurant Extended Warranty underwriters don't believe that the front suspension struts/dampers are a critical part of the suspension system and will not cover them if they fail due to leakage. Apparently, they feel that they are a consumable item similar to a shock absorber. Their warranty does specifically cover McPherson Struts so what's the difference? Probably the cost to them! With the nose lift option, I think that it would show that these are not a consumable item. I provided photos of the struts clearly showing that they were leaking and explained that when going slow over bumps they would emit a clunking sound. I paid $14K for a 4 year extended warranty and am not impressed. It took several phone calls and nearly 3 weeks to finally get an answer. Keep this in mind if you're considering purchasing an extended warranty through Assurant.
