Artura Deliveries
90622 Views 1116 Replies 92 Participants Last post by  JlGem24
Looks like the assembly line is moving …..
Tire Wheel Car Vehicle Motor vehicle
Hood Vehicle Fashion Car Motor vehicle
Tire Wheel Vehicle Car Motor vehicle
Reactions: 1
341 - 360 of 1117 Posts
So far the stock pirellis are significantly better than the new Michelins I just had installed on the 765. I’m spinning like crazy.
That's great to hear! Glad good rubber is finally a default. What is the stock Pirelli and what are you comparing to? PZeros to PS4S?
Reactions: 1
That's always been the case. ESC is calibrated with the specific OEM tires and you have to make sure the proper one is selected in the tire menu.
A conversation from a few years ago; non oem tires are fine for anything that could be related to warranty but wheel size (away from OEM) is the one that can be used to deny warranty related items.
Yes for ESC, but the discussion with Dan was about menu selecting a stem TPMS sensor input.
Reactions: 1
Yes, $2200 wasted. Damn.
Reactions: 1
Yeah, I have found the same thing, I actually lost traction with my old 12C with Michelin PSC2's. Michelins don't seem to grip on the street as well as the Pirellis. My go-to tire has always been the R888R, but I may want to try the Nitto NT01's out back for quietness. I just don't know how it's going to be possible with the Artura. I hope there's a way to toggle to regular TPMS sensors.
Reactions: 1
i use the ps4s, and they absolutely destroyed the pzeros that came with the car, but I have heard pirelli reformulated the pzeros. I would imagine the psc2 might be a bit finicky if cold.
anyway, if more people have been feeling the new pirellis pzeros are better than the ps4s, I’m going to give them a try. I probably have another 6 months before to need to update them.
Reactions: 1
demo car I believe. Needs some calibration and will be ready for test drives next week
Demo or customer car? I read that the first customer car was received by the London dealer today.
The Houston location makes sense because dealers are driving demo cars at Texas Motor Speedway next week.
Reactions: 2
Texas Motor Speedway is about 400 miles North of Houston and a pure oval.TMS is much closer to Mclaren Dallas. Texas World Speedway was a 2.9mile 14 turn awesome track about 80 miles from Houston but was demolished and turned into residential development
I’m not sure of all the talk with the Mclarens only recognize Pirelli tires for the TPMS. Mine is reading the Michelins just fine.
You have an Artura already! 😀
I'm thinking it won't be long before they all have the integrated sensors.
Depends upon what you mean by ‘integrated’ sensors - For Pirelli cyber tire the sensor is literally inside of the tire material layers (and not removable). Other manufacturers also use integrated circuit chips but they are inserted into cups on the inner tire surface and are removable and can work with other tires. Trucking fleets are adopting the chip sensors (removable type) and as usage volume goes up the price/costs should go down and then as you suggest will be adopted by more car manufacturers.
Reactions: 2
there is a reason companies work with Pirelli. it is a lot easier and cheaper to develop a custom tyre with Pirelli than with Michelin. and if you put tyres developed for a 488 or porsche on a mclaren your mileage might vary. especially if you are doing it with tyres from a front engined car to a rear engined one..
So the suggestion by all is that the Artura will run a different TPMS all other Mclarens? I need to go back and read I guess!
Reactions: 1
Yes, with the sensor integrated with the tyre.
What if there is a tire chip shortage and you need a replacement? I hope they've built up enough extra inventory of tires for the inevitable flat tire, etc. Or is maybe the TPMS alarm mute-able?
  • Sad
Reactions: 2
This gives the idea —-
Reactions: 1
This article drops some tantalizing hints about what the current tyre selection in the menu system might do. I'd assumed that it might already affect some of the dynamic traction mappings, but I don't know for sure. This suggests that in future it may not be necessary to select the tyre type manually, the car will already know which ESC mapping is appropriate based on the info it gets directly from the tyre sensor.
Reactions: 1
Yes - I just love being on the foreskin of technology :love:
  • Haha
Reactions: 2
Better buy a Lamborghini then! 🤪
Reactions: 1
