As long as it is fixed properly and it doesn't happen again I'm not concerned .Sounds like you got really unlucky, and had a defective CV joint (which won't be made by McLaren).
I was in an endurance race at Riverside Raceway California in 1981 driving a Porsche . First leg driver came inBlown up CV joint. Going through the gears and then boom between 3rd and 4th. Tech says they've never heard of this before.
Always another weak link when modifying. Appears OP wasn't modified though.CV break all the time on modified 720s.
What car?I was in an endurance race at Riverside Raceway California in 1981 driving a Porsche . First leg driver came in
complaining of vibration . I took over next stint . Vibration went mostly away after maybe 3 laps . Then CV joint broke going to blind Turn 2 at about 130 mph . Car spun then went off the track backwards hit a burm launching it high into the air and rolled various times . I was unconscious during the flight time . Good thing we had a good roll cage and my crew chief always synch up my safety harness super tight
Corner safety crew and doctor thought I must be dead but was just knocked out
So a bad CV joint is not a good thing
Any severe chassis vibration needs to be immediately looked into
Minor track day chassis vibrations can sometimes be eliminated by always taping over the wheel weights
OEM P Zero tires with foam padding inside can also cause vibration when the foam comes adrift
The Pirelli Corsas McLaren Dealers recommended would chunk on a warm track day causing vibration
P Zeros are crap on a McLaren in spirited driving /cornering
Torfeo R’s are great but too expensive and hard to source
