1 - 15 of 15 Posts
Hi all,
When I picked up my car from the dealer after being serviced it has generated an issue when you lock the car, it beeps loudly three times.
Never has done this before.
Doors, engine bay, front bonnet and internal storage are all closed. It had just been serviced and the airbags replaced due to the Takata recall.
Any ideas what it could be? It is going back into the dealer in a few weeks.
Thanks.
@ChaseZimmerman
Hi all,
Thanks.
LOL! Would love to know the answer here as mine does the exact same thing and only started after I picked it up from the dealer, upon it's recent service visit.
On my 570 spider if I arm with something open, like the hood or the engine service cover, it will do something like that as a warning..
Are you guys sure everything is closed properly?
Z.
Triple check the engine hatch cover. Mine double clicks almost. I had the latches replaced under warranty and then realized I wasn't closing the hatch hard enough as the new latches were tighter.
-Troy
@ChaseZimmerman
It's definitely not something open. I remember the sound the car used to make when something was left open, but it was never three audible, independent beeps like this.
in the left display menu, there is an option for audible beeps with lock if I remember correctly.
otherwise, id pop the trunk, the engine lid, and center console and close everything again
It’s the engine hatch. It must be closed with considerable force. Watch for the lock and press hard in this area on both sides.
Before I comment keep in mind I am a new Mclaren owner! Just a total guess. If the dealer reprogrammed the computer for some reason,
it might of gone back to default settings and turned on a warning chime that was previously not on. Just a thought!
Mike
Sometimes its a stuck sensor and opening/closing the frunk/rear engine hatch can reset it.
But if youre saying you can tell the beep is different, then it's new to me.
It’s 3 fast beeps and turn signal lights blinking hectic. Tried to close everything properly several times. Shouldn’t it be just one long beeeeeep if something is not closed?
Can’t find anything in the menu or manual. It really drives me nuts 😬👎🏻
Page 113 of the owners manual "Silent Lock" is what they're referring to.
1 - 15 of 15 Posts
