1 - 12 of 12 Posts
I just picked up my 1st McLaren, a 2018 570S Spider and I’m in love with it.
Someone told me that I should add oil virtually every 2nd gas fill up. As well, I’ve been told that this model doesn’t warn you if the oil is low. Can anyone please elaborate on this?
206642
Thanks in advance!
G
Mine never loses oil. Just check it at fill ups. If it's low, add oil.
Yeah I haven’t needed to add oil. Definitely don’t just randomly add every fill up. Use the measurement setting in the menu to measure the oil and add when needed.
The car gives a generous range from low to max fill but do not overfill as there is no easy way to drain the excess.
Sent from my iPhone using Tapatalk Pro
I've got a 2018 570S Spider that had the second annual inspection 1000 miles ago and it hasn't used any oil. I check the oil once a month which is about 300 miles. Randomly adding oil is bad advice.
Check your oil level in the display menu after the oil is up to temperature, usually 200 degrees fahrenheit or higher. Make sure car is parked on a level ground. No need to add oil unless the car sensor says it's low. Mine never loses oil from daily driving, and only needs a slight amount of oil added after a track day occasionally.
570S Silica White
You definitely don't want to overfill the oil, so as others have said, just check it on a regular basis. If it shows a little low, add a pint and recheck. In all likelihood, though, you will probably find you will not be adding any oil between services.
Thanks in advance!
G
I am wondering who told you this
Friend? Someone who has one?
Must be a troll. Who just adds oil at fill-up. It's called checking the oil level and keeping it full and clean. Same as any gas engine ever made.
Do not add oil. Unless your car tells you to.
Had my 570 for 2 years never ever had to add oil. My R8 on the other hand a litre every 4/5th fill up or so.
1 - 12 of 12 Posts
