@ima2nr (McMedics) Kevin has a selection, and can probably answer your question.
It’s a stronger transmission that can hold more power reliably. Who wouldn’t want that?I'll go first I guess.
Why?
Didn’t think it’d fit honestly. More difficult to obtain for sure.If there is some way to pull this off and it actually could work, at that point go for the 750/765 transmission with the shorter gearing.
yes for the most part . sport trans miss the spoiler fluid ports.I always thought every mclaren till the artura/750/765 had the same transmission?
Nice, thanks for the response. Do you know if it’ll require different wiring harnesses?will work.minor differences in vents but all else is similar. bolt pattern ,splines,output cv are all similar.
It's the same transmission, short of some minor mounting differences. What leads you to believe it's stronger? They literally use the same clutch.It’s a stronger transmission that can hold more power reliably. Who wouldn’t want that?
My spidey senses tell me you haven't actually done it.will work.minor differences in vents but all else is similar. bolt pattern ,splines,output cv are all similar.
Purely anecdotal evidence honestly. Are there no benefits to installing one over a 650s transmission? If not I won’t bother but figured it was worth looking into.It's the same transmission, short of some minor mounting differences. What leads you to believe it's stronger? They literally use the same clutch.
What I can tell you is, 720 transmission won't work (it's been tried, software doesn't jive), and a 650 transmission is identical in every way to a 12C transmission, as well is a 675LT transmission.Purely anecdotal evidence honestly. Are there no benefits to installing one over a 650s transmission? If not I won’t bother but figured it was worth looking into.
Interesting Nice to know that the transmission is “overbuilt” on the 12C/650.What I can tell you is, 720 transmission won't work (it's been tried, software doesn't jive), and a 650 transmission is identical in every way to a 12C transmission, as well is a 675LT transmission.
