Not sure that it matters. I get out, lock the car, open the frunk with the button, plug it in, and don't close the frunk.
Does opening the trunk activate any interior/exterior lighting?Not sure that it matters. I get out, lock the car, open the frunk with the button, plug it in, and don't close the frunk.
I don't think so but I don't remember for sure. Doing it this way stops the warning sounding.Does opening the trunk activate any interior/exterior lighting?
No, but after charging for a full day on Tuesday, when i drove the car yesterday, it said the battery was 77%, but after one hour, it was back to 100% ~ weird!Have you checked the battery voltage?
I need to close the frunk, as the car is outside, in the driveway!Not sure that it matters. I get out, lock the car, open the frunk with the button, plug it in, and don't close the frunk.
Does the 720 have a battery panel? If so, it's really easy to get to it. I wouldn't rely on what the BMS is saying. Fluctuating voltage is a sign that it's bad. Mine would charge, but only hold it for a few minutes before dropping to 3V.No, but after charging for a full day on Tuesday, when i drove the car yesterday, it said the battery was 77%, but after one hour, it was back to 100% ~ weird!
My car is virtually always 100%, because i drive it a lot!
I have no idea, where would it be?Does the 720 have a battery panel? If so, it's really easy to get to it. I wouldn't rely on what the BMS is saying. Fluctuating voltage is a sign that it's bad. Mine would charge, but only hold it for a few minutes before dropping to 3V.
It's in the frunk, on the far wall, where the charging port is. I think the 720 has it, same as the 570, earlier models don't so you have to remove the frunk liner. It just has a couple of plastic lugs that turn, you pull it off and the battery is right in front of you.I have no idea, where would it be?
I wish the car had an easy access panel for the battery!
They typically go up by 1% of every minute of driving. The BMS isn't always reporting correctly. One time in my 12C I opened the door and it said full charge, went to start it and it was clearly quite low. I shut the car off and back on, showing ~35%.No, but after charging for a full day on Tuesday, when i drove the car yesterday, it said the battery was 77%, but after one hour, it was back to 100% ~ weird!
You are correct.It's in the frunk, on the far wall, where the charging port is. I think the 720 has it, same as the 570, earlier models don't so you have to remove the frunk liner. It just has a couple of plastic lugs that turn, you pull it off and the battery is right in front of you.
As soon as the trunk is closed (pressed down), it is locked. The trunk does not have a separate locking mechanism (electronic central locking) like the driver's door, for example, because the trunk can only be opened electronically either way (key or button in the interior) or the emergency release. As far as I know, the central locking only goes to the two doors and the fuel filler cap, but not to the trunk. So seen you should be safe as soon as the trunk locks by pressing down.I just want to make sure i am doing this correctly, while i try to isolate my electrical gremlins!
Do both methods activate the frunk lock, while charging?
Thx
The manual release for the lock is separate, sorta, but you are correct in that there isn't a common link between arming (not to be confused with locking) and keeping the frunk lid latched. It's worth noting, these cars never lock mechanically (except the fuel door). They latch and "lock" is electronically limiting the command to unlatch.As soon as the trunk is closed (pressed down), it is locked. The trunk does not have a separate locking mechanism (electronic central locking) like the driver's door, for example, because the trunk can only be opened electronically either way (key or button in the interior) or the emergency release. As far as I know, the central locking only goes to the two doors and the fuel filler cap, but not to the trunk. So seen you should be safe as soon as the trunk locks by pressing down.
Did you see a green button?On a side note regarding the frunk, I was fooling around with my friends this weekend and I got in my frunk to show them how big it is and realized I don't have an emergency release inside the frunk like I thought all cars were mandated. Were front trunks excluded in this law??
No. Does yours have one? Mine is a MY2020.Did you see a green button?
Thank you!! Now I have to go look again! Maybe it was too bright when we were looking.
