no I haven’t noticed it.OP are you not seeing the flashing light on the dash, this indicates a misfire, as stated you have a safety on, so the throttle is closing.
sounds good. Definitely need the other items done as well.I've got a cousin in Smithtown. We can get get some dates booked and make it all happen at once, along with any other services you need but didn't know you needed them based on time or mileage.
When the spark on mine was getting blown out I very rarely saw a flashing CEL. You could hear and feel it break up, but that's it. I put new plugs in with a tighter gap, problem solved.OP are you not seeing the flashing light on the dash, this indicates a misfire, as stated you have a safety on, so the throttle is closing.
Check your PM's, I sent one last night.sounds good. Definitely need the other items done as well.
Born and raised in Smithtown. Very small world LOLReal small world…
Seen it multiple times. I'm more apt to think the 1,000 HP car isn't making 1,000 HP.have your plugs out and regap them, although i am a little sceptical of this because someone I know is running over 1000 BHP on stock gaps with no problems, apparently.
All I can tell you for sure is I had the experience and changed to tighter gap and fixed it. I've also solved it in other cars doing it.Hes a tuner and has a dyno. thats what hes saying... the car is actually around 1200 horsepower, turbos, tuning etc, meth etc.
Shortening a gap is usually the fix for a "weak" spark.... That is not necessarily the plugs' fault.... And why I was asking about better coils... In my TT RX7, it used a special 4-electrode plug that you CANNOT "re-gap"... As I increased boost level for that stock engine, it had blowout, I fixed it by upgrading the coils!!All I can tell you for sure is I had the experience and changed to tighter gap and fixed it. I've also solved it in other cars doing it.
I looked around and don’t think there are any upgraded coils available.Shortening a gap is usually the fix for a "weak" spark.... That is not necessarily the plugs' fault.... And why I was asking about better coils... In my TT RX7, it used a special 4-electrode plug that you CANNOT "re-gap"... As I increased boost level for that stock engine, it had blowout, I fixed it by upgrading the coils!!![]()
yes that may be the case but that isn’t every car. Just because some cars are ok doesn’t mean they all are. And I would trust mcmedics as he has resolved this issue many times.have your plugs out and regap them, although i am a little sceptical of this because someone I know is running over 1000 BHP on stock gaps with no problems, apparently.
Not arguing that it is not a "fix", just stating that a coil with a better performance envelope is a better fix as the plug gap will continue to widen with mileage.... Then ya gotta do it all over again....yes that may be the case but that isn’t every car. Just because some cars are ok doesn’t mean they all are. And I would trust mcmedics as he has resolved this issue many times.
With mileage? Long before that happens the plugs will be way beyond their lifespan. Thats why its recommended to change plugs if over 10K miles. I guarantee I will NEVER have to change plugs again. You think people are daily driving mclarens. lol But please post a link of upgraded coil packs made for these cars.Not arguing that it is not a "fix", just stating that a coil with a better performance envelope is a better fix as the plug gap will continue to widen with mileage.... Then ya gotta do it all over again....
There are a lot of folks that daily their McLarens and have enough mileage to warrant replacement plugs for optimum performance. Especially if they have been gapped down and "require" that narrow gap to function under said "pressure". Plus, it doesn't take as much mileage as you think when operating in the environment & under the extremes we are talking about....With mileage? Long before that happens the plugs will be way beyond their lifespan. Thats why its recommended to change plugs if over 10K miles. I guarantee I will NEVER have to change plugs again. You think people are daily driving mclarens. lol But please post a link of upgraded coil packs made for these cars.
what research did you do to come that that conclusion? It does take a lot of miles. Dont know a single guy that daily drives their supercar. And I know one guy that has over 1000 60-130 pulls on the same plugs and another guy with over 3000 60-130 pulls. Both did not change plugs. So like I said, I will never need to replace plugs again. And why are you talking about coils that don’t exist? But hey you know better than M Engineering and a mclaren mechanic.There are a lot of folks that daily their McLarens and have enough mileage to warrant replacement plugs for optimum performance. Especially if they have been gapped down and "require" that narrow gap to function under said "pressure". Plus, it doesn't take as much mileage as you think when operating in the environment & under the extremes we are talking about....
I don't have a link to better coils and is why I broached the subject.... ;-)
I went to smaller gap plugs around 30k miles, 46k miles now on the same plugs with no issue and plugs look new still. If you need to replace them every 10k miles, something is wrong.With mileage? Long before that happens the plugs will be way beyond their lifespan. Thats why its recommended to change plugs if over 10K miles. I guarantee I will NEVER have to change plugs again. You think people are daily driving mclarens. lol But please post a link of upgraded coil packs made for these cars.
M engineering recommends changing plugs if over 10k miles to tighten the gap. On stock car it was fine. The gap now is just too wide for the increased boost. But like I said I won’t have to change them again.I went to smaller gap plugs around 30k miles, 46k miles now on the same plugs with no issue and plugs look new still. If you need to replace them every 10k miles, something is wrong.
