thats not the problem.Any ecu will pull timing based on the current operating perimeters on the engine tuned or not, based on temperatures. You will never hit commanded timing on a hot engine, forget about it.
Short of a local shop there is always the McMedics.... They can come to you! @ima2nr (McMedics)
yes They did reply here earlier. Seems like a plan.Short of a local shop there is always the McMedics.... They can come to you! @ima2nr (McMedics)
I think we are getting somewhere now in sorting this out! Thanks for the log! There seems to be a decent following of this thread so I wanted to help others who may see this.
You have a stored engine safety number 11. That is for misfire. Likely plugs and coils. With a log of the misfire occurring on the street we can pinpoint the cylinder the misfire is coming from, however we'd recommend doing plugs and coils in all cylinders. When doing plugs we always recommend OEM plugs at a gap of .022". Misfires due to the ignition system are among the most common issues with McLaren.
I will get you a log that repeats the misfire hopefully before the weekend. But thats so much for the help. You guys respond right back very quickly. I couldnt ask for more!!!I think we are getting somewhere now in sorting this out! Thanks for the log! There seems to be a decent following of this thread so I wanted to help others who may see this.
Are there any "better" coils out there than the "Nissan Sentra" units we have?When doing plugs we always recommend OEM plugs at a gap of .022". Misfires due to the ignition system are among the most common issues with McLaren.
If only all customer service were like this! 😭I think we are getting somewhere now in sorting this out! Thanks for the log! There seems to be a decent following of this thread so I wanted to help others who may see this.
I know right? Everytime I emailed them with a question, and I had several over the past month or so, they ALWAYS got right back to me so quick I had to laugh. They care as much AFTER the sale as before it. They are by far the best I have delt with.If only all customer service were like this! 😭
It would be good if you are replacing to have a better coil. Im going to do some more research on this. I checked quick and couldnt find anything as of yet.Are there any "better" coils out there than the "Nissan Sentra" units we have?
What part? I was debating on going to western NY on the 13th and 14th.
Yup, tunes can do that. Plugs you gotta tighten up the gap and it solves it. I experienced it on mine.The problem seems to be spark blow out. So plugs and coils are needed.
Coils aren't the problem, and there is a varying quality among the application like with anything else. There is a very specific boot it has to have to be able to be installed as well. There is a newer style I've been seeing that won't origami it's way into the car I suspect.Are there any "better" coils out there than the "Nissan Sentra" units we have?
I’m on Long Island. I also have turbo inlets I need installed. And might as well do an oil change since I will be due soon also.What part? I was debating on going to western NY on the 13th and 14th.
I used to live on LI, in Port Jeff, and my wife is from Bohemia… Small world.I’m on Long Island. I also have turbo inlets I need installed. And might as well do an oil change since I will be due soon also.
Yes it is. I’m in Stony Brook.I used to live on LI, in Port Jeff, and my wife is from Bohemia… Small world.
I went to school there!Yes it is. I’m in Stony Brook.
Ward Melville. Very good school.I went to school there!
I've got a cousin in Smithtown. We can get get some dates booked and make it all happen at once, along with any other services you need but didn't know you needed them based on time or mileage.I’m on Long Island. I also have turbo inlets I need installed. And might as well do an oil change since I will be due soon also.
Real small world…I've got a cousin in Smithtown. We can get get some dates booked and make it all happen at once, along with any other services you need but didn't know you needed them based on time or mileage.
