^ what he saysbleh.... good luck with that....
What they both said!^ what he says
I had heard something along these lines also. I think we will learn more when we hear about the P13.I was at the Radnor show over the weekend...talking with all the Mclaren folks...word from higher ups is that the 12C with get an "upgrade" in the spring of 2014...I'm NOT talking IRIS....would not get specific (but smiled when I suggested 650hp)....he was just at the factory two weeks ago..watching the first production P1's start to build...we will all see.
If they are basing their numbers on crank HP, are they pulling the engine for a true engine dyno? In all their other "tunes" they use chasis dynos and calculate the predicted crank HP based on drivetrain losses.All of HPE's kits are based upon crank HP. So it's an 88 HP kit. Apparently the high flow cats are good for +/- 60 crank HP alone. Will larger intercoolers help? Sure. IMO $5k for high flow cats and +676 crank HP is good for me. Jacking with the ECU, intercoolers & boost for an additional 30 crank HP is not worth writing off your warranty and the additional ~$15k.
To HPE's credit they have became a leader in bolt-on performance kits. Sure they can make it as wild as you can afford but the bulk of their business is bolt on performance kits giving folks that 10-20% HP gain before modifications get expensive (motor builds, trans, rear ends, etc.). This is the low hanging fruit and also the most profitable fruit. HPE also gives you a warranty on systems that they install basically picking up what is voided (on factory warranty) by the modification. Since he has TT'd the 458, messing with the 12c is only natural.
HPE seems to be sending a steady stream of wild cars to Russia.... I'm not a HPE spokesman, nor do I have any HPE products or plan to buy any. I admire his business model, it works & is a money maker. The high end market in the US will most likely go to Underground, etc. However HPE has a name, their vehicles are listed in vehicle buyer's guides (aka: banks recognize them and loan the additional money over the base vehicle) & the HPE name increases resale values. Kudos to John, he deserves it. Me and many here are simply not his target clients.
Its all a theoretical calculation - has been since the dawn of HPE. My FGT had the Hennessey 650 kit (pulley & SCT tune) - put down around 605 depending on dyno and weather. Same scenario with all the Viper kits I've been exposed to (other's cars on dyno day). I figure the rationale is that's the way the manufacturers rate the cars.... kind of tough to sell a +100HP kit to someone that only puts down 30-40 HP over the stock "advertised" numbers. It's more of an apples/apples representation.If they are basing their numbers on crank HP, are they pulling the engine for a true engine dyno? In all their other "tunes" they use chasis dynos and calculate the predicted crank HP based on drivetrain losses.
I got my HP/TQ numbers backwards.no one has proven performance wise there is a 60HP pickup from cats/exhaust, just some blown up dyno numbers... no performance figures in my mind means bogus gains, not very hard to go out and test a car... 60-130, 1/4 mile, trap speeds, nada...
business model? no comment, do some searching around and see if you still approve...
I have been in the Viper community approaching a decade - I'm very familiar with the "bad" concerning HPE. The company makes money year after year, over 20 of them.
