1 - 20 of 21 Posts
Does anyone know if 600LT wheels fit on a 570S? I believe a 570s stock offset is 47 and 47 and 600LT is 32.5 and 37
I believe so that 600, 570 and 675 wheels are interchangeable.
that is amazing wow! Especially that style wheels, most get those straight spikes. Do you feel the offsets are more aggressive?
No. I ran them last year and felt that they were still a little 'tucked' so added spacers for a more flush fit.
My finspeeds weren't. Sorry for all the photos. It did multiples and can't get rid of them.
210333
210334
210335
so looks like a 600lt wheel on a 570s will be more tucked in hence why yyzjustin used spacers.
Note the 600LT wheels are 1 inch wider than the 570S OEM wheels. That means they are 12.7mm wider on each side than the 570S wheels. Add 12.7 to 24.5 and you get 37.2 mm offset.
So the wider 600LT wheels are spaced the same on the car as the narrower 570S wheels. I use Finspeed 19x9 et38 and 20x11 et30 on a 570S with 245 35 front and 305 30 rear with no issues.
210373
Discussion Starter · #20 ·
that I didn’t know, assumed they were the same size, because 600LT’s still use a 285 tire. Btw car looks mean and aggressive, especially those beefy tires!
1 - 20 of 21 Posts
