Have you tried switching the MAFs over?
yes sir, one of the first things I did, nothing really changed unfortunatelyHave you tried switching the MAFs over?
Okay, will try, is it hard to change the cam phaser?Could be a cam phaser on one block has gone bad and its causing your timing to go to shit, i think i saw somewhere that you can use a stethoscope to listen to the cam cover and hear the different clicks between the good side and the bad.
If that is the problem then at least you find out your fix, if not you can just pretend you're a doctor in a cheap xxx movie with your cheap stethoscope from amazon
at first i thought about this, but i looked online and the videos just did not have the sound i had.Okay, will try, is it hard to change the cam phaser?
Maybe you could suggest how that is done?Cam phasers dont tend to fail on 570's its usually they spin on the camshaft causing the timing to become out of spec hence you will not hear that clicking noise. There is an updated cam phaser bolt. Most of the time you can just reset the timing with the new bolt and old phaser and everything will be back to normal.
Send me your details❤You are in Dubai, I am here I can help you.
Thank you a lotSend me your details❤
Thank you a lot, i deleted the isg already, will do the throttle body and manifoldYou are in Dubai, I am here I can help you. What OBD logger do you have? Is there a way you can check your fuel trims for me please? If you have an OBD logger you are looking to check the LTFT option in whatever software you are using? Would also be useful to let me know what that is too.
I wish people would stop selling cars here that have issues. I had an issue as well and it took my a year to find the problem because you get idiot mechanics here that actually create problems and dont know what they are doing esp in the UAE.
Dont worry its nothing major hopefully and I will diagnose the problem for you and will tell you how to fix it cheap.
To me from the codes that you have provided (which are not Mclaren definitions) the problem is pointing to either a broken throttle body which ive not seen before but I guess it can happen if some mechanic had it off before and broke it or you have a big airleak under the intake manifold/ISG problem... Have a read up on the Official mclaren codes yourself as the scanners do not give you the correct information.. ECU / DME - McLaren Diagnostic Trouble Codes (DTCs) - M-Engineering - Confluence
Do this, buy another bosch throttle body, they are not mclaren specific and are cheap, you can type in the part code into google/amazon/ebay you should be able to find one locally, they are used on many different cars. If it isn't any better Following this, have the inlet manifold off and check the intake underneith for a pipe that can split and leak, sound generator for leaks looks like a plastic bulb I am 99% sure it is a combination, one of or both of these issues.
If you want it fixed properly speak to Brad at Dragon racing at the autodrome and tell him Michael sent you. Hes ex mclaren and knows what hes doing.
Follow my advice and your car will be fixed in no time. If you need any extra help let me know. You're Welcome
throttle body link amazon.ae
Amazon.ae
www.amazon.ae
McMedics Dubai?You are in Dubai, I am here I can help you. What OBD logger do you have? Is there a way you can check your fuel trims for me please? If you have an OBD logger you are looking to check the LTFT option in whatever software you are using? Would also be useful to let me know what that is too.
Amazon.ae
www.amazon.ae
The MAFs rarely fail. Never seen itHave you tried switching the MAFs over?
